Tool Talk Discussion Forum
WINCH
Rick
04-21-2004 20:21:38
I have worn out my 23 year old 3500 lb winch. Am probably going to buy a 8000-9000 lb one this time. Has anyone had any expierience with one of those from Harbor Freight or should I go with a Warn or Ramsey. I probably use one 4-5 times a month mostly to pull stuff onto my trailer, trucks,tractors, storage sheds or whatever I think should be moved. thanks for the input. Rick
T_Bone
04-22-2004 15:19:46
 Re: WINCH in reply to Rick, 04-21-2004 20:21:38
Hi rick,
Read up on snatch blocks and what they do.
With two double pulley snatch blocks, you can safely move 48000lbs with a 3000lb winch and the correct componets but at a slower speed.
T_Bone
Kirk in PA
04-22-2004 08:58:50
I bought one of the Harbor Freight 8000 lb winches last year. I fabricated a mount to the front of my trailer. I have only used it about 6 times to pull my AC 20-35 onto the trailer. I take it off and store it inside. Seems to work OK, but I'm sure that you get what you pay for.
Irving Baxter
04-22-2004 04:31:35
I've had great luck with Superwinch. Quite a lot cheaper than the bigger names, but strong, long lasting machines. I use a 3500 lb X3-F to load logs (some HUGE ones, too)on my Woodmizer. It'll get used 50 - 100 times a day for about 3 years before it dies. A new set of magnets and armature and it'll be like new again.
