Tool Talk Discussion Forum
Another Dumb Question
Allan
04-21-2004 04:44:27
Hi All,
I've got one of these "lumber yard built" wood lawn sheds shaped like a little dairy barn...what are they something like 8'X 12'?
Anyway I have to turn it 90 degrees & move this thing about 15 feet. What's the best way to move these things?
Can I just "bump" it around with my loader bucket or will that tear it up?
Thanks,
Allan
Bob
04-21-2004 15:40:32
 Re: Another Dumb Question in reply to Allan, 04-21-2004 04:44:27
The only dumb question is the one that goes unasked.
tim in wi
04-21-2004 14:04:10
thats how i got my shed frend wanted empty shed moved 75' went home got loader tractor got about 15' it just came apart floor walls roof so he said he was going to burn it i said i wanted it took it home rebuilt floor with 6x6s & 3/4 plywood [ stoneboat ] and it moves with no damage now i move it in a large garden / veg stand ill bet it has 10 mi on it
Chuck (VA)
04-21-2004 09:06:58
To keep from racking the walls during the move
screw diagonal braces from top of wall to floor on opposite corners which you can remove after the move.
If on 4x4s runners nail 2x4s across ends to keep them spaced otherwise on the 90 deg turn you will rip them off the floor studs since they are usually just toe nailed in.
greenbeanman
04-21-2004 08:21:14
A neighbor insisted a couple of weeks ago that I use my tractor and loader to help turn and move his shed 90�.
I looked it over with him and told him it would best be moved with rollers and pry bars. Nope, he wanted it done with tractor.
At the appointed time I met him and a few friends there were going to oversee the process. I told him that I did not think it would work, but if he insisted I would push where he told me to, with him assuming all of the liability.
End result, only a few broken boards such as the rim joist and some trim. Oh, that was without the shed being repositioned by the way. Shed was empty too.
He and his buddies used a Sawzall to cut the roof off, set it off by hand, turn the lightened lower portion, then reinstall the roof and trussing system.
Yup, use some fence posts for rollers since you probably already have some of those. Good luck.
Steve from Mo - I dunno..
04-21-2004 08:06:36
A tag sale might work better. Sell everything, including the building. Buy a hammock. Hire people to come and do the stuff that you used to do when you had tools and equipment.
Mattlt
04-21-2004 05:32:01
Allan,
I'd jack it up slightly, and roll it on some pipes. Expecially since you're not going very far.
Depending on the "undercarriage" of the building, 3-4 3' pipes under each side may be all you need. Once it's on the rollers, you should be able to push it by hand.
Matt.
Allan
04-21-2004 06:32:52
 Re: Re: Another Dumb Question in reply to Mattlt, 04-21-2004 05:32:01
Matt,
Great!! I'll give it a shot.
Now, to clean the darned thing out first!
Allan
Sam#3
04-21-2004 07:59:21
 Re: Re: Re: Another Dumb Question in reply to Allan, 04-21-2004 06:32:52
Keep all the pressure on the floor frame, if possible. Too much pushing on the walls will rack them.
DumOleBob
04-21-2004 07:10:46
A good way to clean it out is to open the door. Then with your loader at the end opposit the door lift it up to about 75*. Most of your junk, which hasn't glued itself to the floor, should just roll out.
Next, go down to the lumber yard and but a new building since the old one will have broken in two...:-)
Vern-MI
04-21-2004 11:38:20
 Re: Re: Re: Re: Another Dumb Question in reply to DumOleBob, 04-21-2004 07:10:46
Bob, why not just tell him to wait for a tornado and collect the insurance?
Brian G.
04-21-2004 20:09:29
 Re: Re: Re: Re: Re: Another Dumb Question in reply to Vern-MI, 04-21-2004 11:38:20
I heard that someone (maybe the Amish) moved a REAL barn by fashioning a hand rain all around the inside of the building, and lining it with people who simply picked it up and walked it where the wanted it. I bet you could screw some 2X4s around the outside, get a keg of beer, invite some friends and put that building anywhere you want it.
