Tool Talk Discussion Forum
Wagner Loader
Steve L
04-20-2004 20:16:08
I have a IH 404 and just mounted a wagner loader on it. I tied the hydralics into the axilary vavle, it works but I have to leave the auilary vavle in and it then trips the relive and sqeals. the loader has its own controls. Any know where I can tie in for where I could find info on same
JT
04-20-2004 23:26:38
 Re: Wagner Loader in reply to Steve L, 04-20-2004 20:16:08
What do you meen by leaving the aux valve in?
Sounds like you bought a loader that was plumbed for closed center hydraulics and I think the 404 had open center.
If this is the case you will either need to adapt the valve for OC hyd or get a different valve.
Here is a link for valves and the catalog from this outfit has some basic Hydraulics tutorials.
HTH
JT
Steve L
04-21-2004 03:43:59
 Re: Re: Wagner Loader in reply to JT, 04-20-2004 23:26:38
JT - OC does that mean open center - does an open center circulate when its not in one position or an other? The loader came off of a 2606, that is the same as a 606 except the comercial version. Maybe the hydralics are different. thanks fo the reply
JT
04-21-2004 08:29:43
 Re: Re: Re: Wagner Loader in reply to Steve L, 04-21-2004 03:43:59
OC in that case meant open center. I am not intametly familiar with that era of IH tractors. But I think both units you describe are open center. Maybe someone who is more experienced with 60's era IH will weigh in.
In open center systems the fluid is always flowing through the valve at low pressure. When the valve is actuated the flow is redirected and pressure is built up until the work is done and valve released. In closed center system is always under pressure and no fluid moves until called for. The pump shuts down when pressure is built up.
Hope this wasn't to long winded
JT
