I am a mechanic for a major airline in their main maintenance base. The type of work I do requires that I use a torque wrench frequently. The one guy in the company who calibrates every torque wrench the company has, (hundreds, if not thousands) has his little shop just off the hangar floor and is quite friendly and doesn't mind talking with mechanics and "checking" their torque wrenches brought in from home just for him to check. (we are required to use company calibrated tools and cannot keep our own stuff to use at work). I have spent a couple of hours in his shop getting an education in Torque wrenches and their use. We have many different brands and he has seen lots of expensive ones and cheap ones too. The cheap ones from such as harbor freight are many times just as accurate as the best ones on the market, but you have no idea unless you keep them certified (true with any tool) The expensive ones, and snap-on ones bring high prices on ebay, I've been watching them closely of late, are not always the best. The newest micrometer ones snap-on sells are very good, and the old dial type ones are good also. The older micrometer type are not so good. Snap-on has recently purchased a couple of different companies that make torque wrenches, is why the newest ones are the best, there have been many improvements in them. Beam type are the most accurate, generally designed to +/- 4% or better accuracy and many of them to 2% or better. most click/micrometer type are 6% and some of the better ones are 4%. They are frustrating to use as you have to watch the pointer while you are torqing, same with most dial type. Our company won't allow any with worse than 3% accuracy variance over the full scale. The dial type, rigid ones are generally very accurate unless someone has exceeded the max limit, at which point it is junk and not repairable. Protos are good, difficult to adjust if out of calibration. Sturtevant Richmont www.srtorque.com are the best we have at work. They are accurate to generally 2% or less and repeatability (the ability to set the tool to a specific torque and on the tester consistently get the same readings many times over) is phenomenal, he showed me one on the tester. Utica ones are also good, nothing special, and Seekonk >Link CDI and TCI also make good ones, I think CDI was the company acquired by snap-on. Treat any one you have with care and dont throw it around or drop it and never exceed the max torque limit. Also never use the torque wrench to loosen anything unless it is designed to read torque in a CCW direction and only then use it to read torque CCW if the work requires it, otherwise switch to a breaker bar or ratchet. Finally, release micrometer types to the lowest torque setting (BUT NEVER LOWER, especially Protos, as some of them come apart internally when you go below the lowest torque setting) Keep it in a box, case or special place in the tool box drawer where it doesn't get harmed, they will last a lifetime. Charles
