Tool Talk Discussion Forum
Small Irrigation pump
Jason
04-19-2004 11:08:09
I am looking for some ideas on garden watering. I have a 550 gallon tank I plan to use for hauling water for watering the garden and newly seeded lawn. I am looking for a pump to pump it out of the tank and thru a sprinkler system. What can any body suggest. The output needs to be 3/4". Most pumps I have found are for a higher volume setup. I am concerned that if I restrict a larger pump down I will casue problems. And of course as always the cheaper the better. Gas powered would be more convenient but I could make an electric pump due.
jtex
04-21-2004 12:43:47
 Re: Small Irrigation pump in reply to Jason, 04-19-2004 11:08:09
whatever you buy get a good one(goulds,myers).I work in pump sales and see it every day, someone comes in and wants their pump fixed and its always some xyz brand that they got a lowes or home depot. parts are almost imposible to get and most of the time they are not even worth repairing.walk into your home improvement store sometime and ask for a replacement mechanical seal or impeller for one of their pumps and they will run backwards. spend the extra money up front for a good one. you will be glad you did in the long run. a small jet pump will work well, there are a ton of them running around here for just what you are wanting to do. just my .02 worth
MAC,IL
04-20-2004 10:05:05
More ideas and pointers.
http://www.waynepumps.com/
T_Bone
04-20-2004 01:29:49
Hi Jason,
You first need too figure your pumping demand, ie; GPM, then you will know what kind of pump you need.
I also haul all my water, 1200gal at a time, and for the garden I flood irrigate for deep watering twice weekly (Arizona) with a direct siphion feed from the tank. 2" tank oulet x 3/4" garden hose "Y".
Then I use a 1/2hp (115/230v) jet pump with a bladder tank for the pressure side of the garden (hose etc) and the house.
The bladder tank keeps the pump from cycling on so often and prolongs pump life.
Pump about $200 and bladder tank about $300 at Home Depot, etc.
SurFlo RV pumps are typical 12vdc, 3gpm, @35psi, and 3gpm is not all that much for garden/lawn use, real slow watering. About $55 at Camping World. Can be used with a bladder tank or a 2" x 6ft capped pipe (acts simular to a small pressure tank, smoothing flow). I use one with a solar pannel on my RV that works very well for that use.
You can throttle (ball valve) the discharge side of a pump but "never" the suction side of the pump, (creates pump cavitation (air))
T_Bone
Mattlt
04-21-2004 05:28:20
 Re: Re: Small Irrigation pump in reply to T_Bone, 04-20-2004 01:29:49
T_Bone,
You mention the 2" x 6' capped pipe. Mounted vertically, I assume? Is there anything "magic" about the size/length of the pipe? Would a shorter, wider pipe work differently?
Does this smooth out the "water hammer" effect, and/or truly act as a pressure tank? Suppose you could also add a Schrader valve to the top to pump it up a few PSI...
Now you've got me thinking...
Thanks,
Matt.
Remove xxx to email.
Steve from Mo
04-21-2004 08:11:45
 Re: Re: Re: Small Irrigation pump in reply to Mattlt, 04-21-2004 05:28:20
Mount vertical, it is the height that modulates the pressure. It will reduce hammering but will not allow you to build pressure to use later when the pump is off. You need a pressure tank or bladder tank for that. Adding air at the top would effectively shorten the tube and reduce the usefulness. A short wider pipe would not work as well for the same reason.
T_Bone
04-21-2004 17:14:17
 Re: Re: Re: Re: Small Irrigation pump in reply to Steve from Mo, 04-21-2004 08:11:45
Hi Matt,
To rid ones problem of water hammer you need a stand pipe above the water outlet. This traps air in the pipe as air will rise to the highest point in a piping system.
For my RV, I layed my pipe (expansion cylinder) on it's side under the bed. My pump was putting out slightly more GPM at the facet than the facet would dispence wide open and short cycle the pump. The pump works on a pressure switch and it doesn't take much pressure drop to kick the pump on. After installing my pipe, the pump would not short cycle as it was trying to fill the expansion cylinder as well as supply the facet demand thus a smooth flow.
Using the above theory then you could also mount the expansion cylinder (pipe) vertical, add a air sniffer thus create a pump pressure tank (works on the same theory as a bladder tank).
T_Bone
eric hendricks
04-19-2004 19:27:14
I've watered our garden with a homelite 2 cycle pump for a few years.It has a 3/4 " garden hose output on the pump. They put out a lot of water fast and are pretty small and don't cost much. It is the same moter that is on their weedeaters.
Jason
04-20-2004 14:36:10
 Re: Re: Small Irrigation pump in reply to eric hendricks, 04-19-2004 19:27:14
Where did you get your pump? What model is it, AP125?
Angle iron
04-19-2004 18:11:58
cheek out harbor freight at www.harborfreight.com they have 12 volt,120 volt and gas driven pumps some of their stuff is pretty good and some is shall we say (cost effective)
Johnski
04-19-2004 16:07:57
Go to your local RV dealer and get a camper water pump. It runs on 12v and will probably supply enough pressure to run a sprinkler. Or you can go to the hardware store and get a cheapie drill pump with a 1/4" shaft that hooks to an electric drill. Those pumps are both available with garden hose fittings on them. Plan B, tear the pump outta an old washer and rig something up. ;>)
RZ(Wa)
04-19-2004 14:50:05
One of those little electric sump pumps may work. They are set up for a garden hose to be directly attached. If you go with a larger pump, you'd probably be looking at adding a TEE and a gate valve in the mainline to regulate the volume and pressure and to keep from burning up the pump. Easy and cheap to do and you'd be able to run more than one or two sprinkler heads at one time.
Coloken
04-19-2004 12:07:16
How about checking at swiming pool places? I have a neet 1/2 hp pump I got from my brother that was part of a pool filter system. Looks kind of like what you are looking for.
