Tool Talk Discussion Forum
Electrical wiring question
Rusty G.
04-18-2004 15:00:05
Can anyone tell me how to wire 4 plugs(actually two plugs in 1 double box)in a double box in the middle of a run. This is using 12/2 wire in 120 service. I have some electrical experince but still not too sure about this one. I have a book but the book only shows the box on the end of the run. Thanks a bunch
Charles (in GA)
04-18-2004 17:19:31
 Re: Electrical wiring question in reply to Rusty G., 04-18-2004 15:00:05
Well, for starters, here is a real good web page that shows a single receptacle in the middle of a run.
Link
buickanddeere
04-19-2004 05:00:39
 Re: Re: Electrical wiring question in reply to Charles (in GA), 04-18-2004 17:19:31
The grounds as well as the line(s) and neutral need to be joined with a wirenut in each box and three or four pigtails brought out to each receptacle. The reasoning being if a receptacle is damaged and/or removed the rest of the receptacles down stream are not left without a neutral or ground. Contrary to the opinion of many persons, a wrap of tape around the wirenut is not required or desired.
Rusty G
04-18-2004 19:04:17
Thanks for all your help.
