Tool Talk Discussion Forum
Wood Pole, Vs. Steel Farm Equip Storage Barn
Scotty
04-17-2004 23:01:28
Been Looking at both Wood Pole buildings, & steel frame buildings.
The questions...
1) What do You prefer?
2) What should I watch out for?
3) What kinds of experiences have You had with warranties, etc?
4) Now any good reputable builders that cover West Central Indiana?
I am planning on about a 50' x 60' x 16' building give or take with maximum protection from the elements! All responses welcomed as always! Scotty
Dan Kelley
04-20-2004 08:53:39
 Re: Wood Pole, Vs. Steel Farm Equip Storage in reply to Scotty, 04-17-2004 23:01:28
I'm in the middle of putting up a 50x75x12 steel building. My final cost will be about $30k. The building kit cost me $14k, because I have several 9x9 and 10x10 side doors. When I decided to go with the steel building, Morton quoted me $48k for a 40x60x12. So, I got more building for less cost by doing it myself. My wife and I have been doing most of the work, and yes, we're still married!!!!
I am in a residential area zoned for horses. Probably doesn't affect you, but our regional building department is rather strict. I could put up a pole barn for agricultural uses with minimal permitting, but a garage does not qualify for the agricultural exemptions to permitting.
A garage is not considered agricultural. So, I had to go through full permitting. Getting a full building permit for a pole-barn is considered impossible in this area, because the plan-check folk want full drawings with calculations. Steel buildings come with full drawings and calculations. Plan-check was a breeze. Full permitting also helps with the insurance company folk.
Also, FYI VA/FHA sometimes will include outbuildings (e.g. detached garages) in their appraisals for a VA/FHA loan. The key word is SOMETIMES. They will absolutely NOT include pole barns, and will NOT include round-top buildings. That only left steel buildings. Since I live very close to Peterson AFB, Schriever AFB, the Air Force Academy, Cheyenne Mountain AFS and Fort Carson, it was a consideration whether or not it would go VA/FHA.
One last thing. We live in an area where 87mph is code for wind loading, but there have been winds in our neighborhood clocked at 93mph. In that storm, a neighbor lost his pole barn, and 13 power towers were toppled. There was pole barn sheet metal all over the place. My building is rated for 100mph winds.
MarkB
04-19-2004 03:56:57
In the size you want to build, post frame is going to have a big price advantage over a quality all-steel building. Get some bids and you'll see. The trusses on a post frame building will cut into your overhead room, but some of the manufacturers now have buildings that combine post frame construction with steel trusses so you get the best of both worlds.
There is such a range of quality in all-steel buildings that there are probably some that are priced competitive with post frame. You'll be much better off with a quality post frame than a cheap all-steel. Of course the high-end all steel building are the best, if you've got a $100K or so to spend.
jonesy
04-18-2004 18:46:14
I have a steel Mueller building that is rated for 100 mph wind, 20 year side and roof panels. I really love it for my work shop. It is 30x40x12. Im in need of another building for restored machines. One thing to remember is the cost of steel has gone up as much as 60% in the past 3 months. Steel companys will give you a quote thats only good for a week. Im a fan of the steel but cost has me leaning towards wood.
J.C.H.
04-18-2004 18:11:24
I'M NOT EVEN GOING TO READ ALL THE SUGGESTIONS YOU ARE RECEIVING BUT WILL CUT RIGHT TO THE QUICK AND TELL YOU TO CONTACT MORTON BLDGS AND GO FOR IT. THEY ARE BY FAR THE ULTIMATE BUILDERS BAR NONE OF POLE STRUCTURES WHICH WILL SERVE FAR BETTER THAN ANY STEEL FRAME ON THE MARKET.I'M FROM NORTHERN IL. AND HAVE SEEN WHAT HAPPENS WHEN A MONSTER STICKING SNOW STORM DOES AND HOW QUICK BUILDERS RESPOND AND ASTRO, CLEARY, WICKS,WICKES,ETC,ETC DO NOT COME NEAR THE SERVICE MORTON BLDGS. PROVIDE.
KURT (mi)
04-18-2004 16:56:26
I would get info on reputable dealers of the steel barns and ask around when you find what you want. First ask to drive to a customers place that has put up an "X" building and ask the questions, were all materials delivered without damage, were all materials there? ease of assembly bla, bla, bla. I have never put up a steel building, but I built my own home and I had good subs doing the work. One thing to keep in mind when you build the shop is that if you go with a wood barn you can nail wall coverings and electrical boxes onto wood studs easier. also if you ever think to make part of the barn a game room/play room/away from the wife area with the buddys then think of being able to turn it into living space. Just my thoughts
ShepFL - Long post with
04-18-2004 16:26:46
Extract of an email I sent to a fellow Oliver :) fan. PS - if you use the email delete the word (remove).
Lessons Learned or Work Shop Considerations
As to the shop I would strongly recommend steel vs. pole barn etc. Make sure to pre-drill wall sheets before ASSY!! Also run a stringline down the ridge cap to maintain a straight screw line.
This is by no means all the considerations but enough to ignite some other thoughts. Email me and I can provide an Excel residential home construction checklist/loan calculator for other thoughts and a comprehensive builder's checklist. Planning
I put up a straight wall steel bldg. from Millennium Steel with full fiber and rebar reinforced concrete slab (~14K bldg & slab only). Walls are 24ga & roof is 26ga. Screwed up & did not add insulation - so far no issue but told it will be in the future. I would spend the extra and get the insulation. I would NOT recommend Millennium Steel. Plans are vague and you must hand assemble every single component. Consider some else such as Mueller, Steel Building Systems (Adel, GA) or others (Morton $$$$). The uprights are pre-welded so all you have is an adult sized erector set.
Bldg is 30w x 60L x 14h enclosed. I added a 10' slab extension at the rear for fuel storage. Still haven�t added a lean to of the east side for parking my equipment on dirt floor nor covered the fuel storage area. I looked at pole bldgs. & cost was nearly the same as steel. Also much less maintenance in FL with steel (termites etc.). Also with steel you can get a bigger �clear span� than with wood. Code here requires 120MPH wind load (hurricane) on structure and doors.
I did not like Quonset style due to lost storage space because of the wall construction - ridges and lost storage space due the arch vs. straight walls. The ridges were throughout the entire structure, and I thought it would be a hassle when wiring, plumbing, adding workbenches etc.
I also wish I would have built mine on a 3 or 4 ft. stem wall. I could have gone to a taller building with no more expense from the supplier and reduce the need for special equipment to move longer sheets of metal. It also permits installation of a taller door at less cost and the stem walls provide protection of the door from the trailer being backed in or an implement. If no stem wall consider PVC filled bollards at the door entrances.
I have no windows just big doors opposite ends of the shop for cross-ventilation. One personnel door and NO SKY LIGHTS!! Everyone I spoke with says they wish they had not put them in. They last about 5 yrs. and then nothing but HEADACHES. My recommendation is to steer clear.
You should plan on needing approx. 4� around a rig to work on it -16ft., so that leaves 3ft for work bench and tools on one side and maybe one end, so you will be left with an area of 16 x 20 for unit- 16 x 23 if leave end bare. Be sure to allow room for tools- welders, chop saw/band saw, drill press, lathe, air compressor
Hoping to add a loft or mezzanine this summer for overhead storage and wall off an office area for sippin� fine bourbon & a bathroom in the back corner with deep sink and toilet.
Heating will be an individual thing, mine is unheated but I live in SUNNY FL :)
I would also consider some overhead plumbing for shop air besides outlets along the wall. Then you can install a retractable hose line and not have the hoses all over the shop floor.
Gutters are optional. Here is a link for some on-line plans if you need some other ideas. http://www.ag.ndsu.nodak.edu/abeng/plans/ Flooring
I debated on the gravel for some time. I decided on full concrete for the following reasons: #1 - Once done it's done!
b) Two pours more expensive
c) Two pours more effort to get & keep level & get the truck's chute far enough inside to reach new pour location.
d) Work on my own rigs, creeper won't roll on rock
Less time to clean, hose down and squeegee, plus less moisture inside the building thereby reducing other misc. maintenance
e) Gravel will be outside for outdoor equipment storage but not inside.
Hindsight is 20/20 so also consider some buried anchors or chain to use to pull against to straighten parts. Also think about 2� or 3� embedded pipe stands for grinders, etc.
Concrete drive-in ramps are next addition to my shop so I can clean rigs outside then drive in. Not to fun having to always clean up shop floor from grungy rig or implement.
I also poured a 10' concrete extension in the rear for future use - fuel storage and (Jim Beam & my easy chair?).
I also put in a floor drain with a 6� drainpipe under the slab out to the rear of the shop. Concrete guy did a pi$$ poor job with this during the pour. The drain floated up some as did the pipe. A current consideration for me is install a drain grate down the center in at least 2/3 of the shop to wash-down whatever. This would be connected to a drain line into the swale below and behind the shop.
Lighting
For my shop 30W x 60L x 14H here is what I am currently doing. I have brought 200amp service to the shop in 42-circuit panel. Bigger panel was selected for expansion if ever needed (bought it from electrical contractor during house construction).
I am wiring lighting outlets every 10 ft. on center set out from the wall about 6 ft. I have also have one overhead outlet for every 100 sq ft. (ceiling fan or drop cord).
I am using 4 bulb fluorescent fixtures I scrounged from the dump. For each row of lights I am installing 3-way switch switches at each entrance to prevent back tracking and improve efficiency. For bench work I am installing 2 outlets with a wall control switch. Right now the bench lighting will be incandescent with hopes to replace this with 150W reflector bulbs later. These lights will be about 4 ft. above the bench.
Outside lighting is mercury vapor with dusk-dawn controls (Lowes Store) on front and back entrances. One day the sides will be covered with motion sensor flood lights (Lowes store) to come on when parking equipment and to be a deterrent.
General use outlets are 20amp duplex spaced every 4 ft. of wall space (overkill for sure). In case I reconfigure things (move the barley pop machine or toaster oven) I don't want to run out of outlets. I have one GFCI outlet for each wall. I have also dedicated one outlet for each tool less than 1/2 hp.
Special purpose outlets are planned (but not yet installed) for tools 1/2 hp or bigger. Both the general use and special purpose outlets will be on branch circuits to serve no more than three 1/3 hp motors, two 1/2 hp motor or 1hp or bigger.
I also have plans for four 50 amp 2 wire with ground outlets for my ancient DC welder (Lincoln DC 250-MK Aircraft) and my air compressor. One of the welder outlets is going to be placed just inside the main roll up door so I can repair equipment outside without having to remove implements etc.
Heating is really not a concern in my area (N. FL) as it does not get bone chilling cold here but the overhead outlets will provide ceiling fan cooling in the warmer months.
One thing I rarely see mentioned is painting for reflectance. When done my shop walls will be painted with a light matte off-white color and ceiling will be painted ceiling white. This should improve lighting efficiency. This is something that can be done by all of us and cost is just paint and some elbow grease. No code constraints that I am aware of :)
When I am done it should be rather nice place to work. This project has been a work in progress for nearly 2 yrs. I am now about 2/3 complete. The above is my PLAN so when finished I do not have to come back and rewire, add etc. Once it is done it is DONE (or so I hope).
Wiring
To save myself time and ensure safety I obtained one of these manuals - http://www.nfec.org/electricalwiring.htm
As copied from the website; "To avoid Code violations the Agricultural Wiring Handbook offers help. The newly released 13th edition provides wiring information for swine buildings, dairy and beef operations, poultry facilities, as well as farm shops, machinery sheds and grain facilities.
Contained in 34 separate chapters, the 100-page Handbook also covers farmstead distribution topics, three-phase wiring, grounding and lightning protection, motor circuit requirements and newly-updated wire sizing tables." Perhaps one can be found at your local Extension office or Ebay.
Also installed some speakers so I can listen to the NASCAR race, talk radio or some music.
I would suggest putting in a phone line and ringer next to the barley pop machine. Also make sure phone line has extra pairs so you provide an Internet outlet for the YTMAG session during quiet time with a barley pop :) Believe you me, those wireless phones DO NOT work worth a hoot inside my metal structure.
Shop Air
I hope to plumb the shop with air with outlets near each electrical outlet. Plumbing will include an overhead line with retractable hose reel to prevent having lines all over the shop floor which can be a PITA (ex-aviation jobs taught me that).
Overhead Dolly/Jib Crane
My shop will not permit this but it sure would be nice. Currently using a cherry picker for engine work.
Hope this helps some
PSS - fotki has blocked my account. I will get it reactivated soon so you can see some old pics of the original construction efforts.
ZK(Wa)
04-19-2004 15:37:14
 Re: Re: Wood Pole, Vs. Steel Farm Equip Stora in reply to ShepFL - Long post with , 04-18-2004 16:26:46
Hay Shep, is there anything you left out? Appears you lined out or at least considered most everything useful or needed. Thanks
Charles (in GA)
04-18-2004 08:35:15
There are a mulitude of metal building companies, the quality ranges from Cadillac to Yugo and everything in between. Talk to several in your area (shipping costs, you don't want to go too far away) and get referals and go look at them. Another reason for sticking with a manufacturer close by is that they will be more familiar with your local and state codes and can produce what you need and not more or less, as far as snow load, wind load, etc.
Spend as much time looking and learning as you can before you decide, it will be much less stressful on you when the building goes up, if you know what to look for, if its being done right or not.
You can visit my web site for a whole two web pages with lots of pics, on the construction of my 60x60x16 aircraft hangar. Warning, lots of pics, takes for ever to load with a phone modem.
Link
txblu
04-18-2004 07:10:39
I started out with wood building my own cause I didn't have a portable welder. Now I do and everything is steel. If I want wood inside, you can use sheetmetal drive screws to install a tab to the perlin type steel to attach your wood.
I have a 1000 sq ft Morton built in 1981 and the paint is still good (needs a good washing) and the structural wood is ok. Some of the perimeter trim wood (on the ground) has been worked over pretty good by the little white teethy six legged critters that live in the ground. Today I would go with steel however.
I think the insulation wrap for the ceiling at least is a must for the reason given. I also vapor barrier sealed the floor but in TX. when the south wind blows for days bringing the Gulf of Mexico moisture in and the dew point is just right it will sweat regardless. The front (cold) comes in and in hours it all evaporates.
We have a company down here that has registered engineers to do your plans and know what they are doing with steel. www.Muellerinc.com.
If you are too far away, you could still get some ideas. There are lots of companies that will build for you and do a good job.
My suggestion for a building that size is get proof of engr approval, and check the reputation of your builder.
Steel is said to be a little pricy now but this building will be here the rest of your life!!!!
Good luck
txblu
rustyfarmall
04-18-2004 06:59:46
Definately do not go with Morton, I had them put up a building for me about 5 years ago, and while the building itself is o.k., I had major problems with an inexperienced building crew,backed up by the corporate people who just didn't care, and topped off by the local sales people who also didn't care once they had their money. Do an internet search for Morton buildings, and you will come up with a multitude of lawsuits against Morton, ranging from deadlines not being met, shoddy materials, and completed buildings which do not meet the criteria of what was set forth in the original contract. I am not the only one who has had trouble. There are others on this forum who have also had trouble.
Dusty
04-18-2004 06:29:22
I would say that most reputable builder would be Morton. They have been in business for 101 years, have a good warranty.
Dieselrider
04-18-2004 05:50:46
There are advantages to both. One thing to keep in mind, if you are in an area that gets frosty mornings on sunny days, you might want to put something like house wrap under the metal roofing or some type of moisture barrier. I built a small equipment shed a few years ago and did not do it then and when the roof gets frost on it and then the sun hits it, it does drip inside. Not real bad but, it does and the building is not heated and is open on one side. I built a 40'X60' machine shop a year and a half ago and used the wrap under the steel roofing right over the purlins and that building is heated and I have no dripping problem. Just my 2 cents.
Steve-Maine
04-18-2004 03:04:37
I bult a pole barn for me equipment about 30 years ago. 3 sided with south side open. When it snows I get a little in but within a day or so it melts away. I used metal roofing and got the poles free for haul;ing from local phone company. Sometimes when they are relocating a road they will give you the poles for hauling away. I'm building a new 32x 50 shop but am building regular building with metal roofing.
Steve
Ken
04-18-2004 12:18:44
 Re: Re: Wood Pole, Vs. Steel Farm Equip Stora in reply to Steve-Maine, 04-18-2004 03:04:37
I would look around for a good company that has good reputation and warranty. I would advise against a Morton Building. They are overprice crap put on sticks. I own 2 of there buildings and I'm considering dozing them down and putting up something else. I am the second owner and the building are around 12-13 yrs old and the sliding doors are rotting away along with boards at the bottom. Since I'm not the original owner of the building they wont even acknowledge that I have one of their buldings for repairs on materials. I've talked to other owners in my area and the laminated upright beams they have had to replace after a few years because they rotted off. I'm suprised my shed hasnt blown over yet. I think when the time comes I will put an all steel. If you want the Weeny go with Morton but I would do my homework first.
