Tool Talk Discussion Forum
Depressed center blades wear out too fast.
Spence
04-16-2004 11:02:37
Ok, I've had it, I'm tired of spending $$$ on corundum based 7/8 X 7in X 1/8in depressed center metal cutting blades that last all but 15 minutes.
Time to find me the ones made of diamond dust.
Anyone know where to find them?
Wayne
04-19-2004 21:03:37
 Re: Depressed center blades wear out too fast. in reply to Spence, 04-16-2004 11:02:37
If they have the wheel you want in the right size, try one of the NORZON grinding wheels from Norton. They have a ceramic in them and are really cutting fools. If you look at the metal "dust" they throw off you'd see it isn't just a dust particle, it comes off in a miniture sliver like you'd see in a larger scale coming off a lathe or mill. We use them almost exclusively now and they outlast everything else we've tried at least 4 to one or better. They are about twice the price, but they are well worth it. If your looking for a nice, relatively smooth finish though find something else because they do tend to leave a rough finish just because of the way they cut the metal to remove it.
Fred OH
04-19-2004 08:59:27
Spence...you might try using the 7 x 1/4" wheels and get a lot better service from them. I once watched an employee using the right angle grinder and when he was through with it, he would stop it by shutting off the switch and grinding it to a halt on the workpiece. If you apply the rule that the faster a wheel runs-the harder it acts...then the opposite is true in the slower it runs-the softer it acts...and grinding it to a halt like he did helped shorten it's life somewhat. You might also try another brand, I've seen some that the bond wasn't quite up to snuff with others...or just a plain bad batch. Just some thoughts from experience through the years. Fred OH
