Tool Talk Discussion Forum
easy to get parts washer fluid?
chuckinnc
04-16-2004 10:15:10
What would be good to use in a small 3 1/2 gal.
parts washer, is there anything common that works
well like diesel fuel or other stuff you would find around a country store ?
Fred OH
04-19-2004 09:06:09
 Re: easy to get parts washer fluid? in reply to chuckinnc, 04-16-2004 10:15:10
For years we used mineral spirits as the general purpose solvent (read cheap)...about 2 or 3 bucks a gallon. Has it been outlawed? I don't think it was any more flammable than diesel fuel. Fred OH
Mark
04-17-2004 14:37:27
Haarbor Freight has concentrated fluid that is about $8.00 a gal. A gallon will fill a 20 gal cleaner. It's not as strong as others but it leaves no oily film and it won't catch on fire. I buy it in the store but I expect you can order it online. Hope that helps.
Brokenwrench
04-17-2004 12:25:56
I use Varasol in mine. My fuel distributor sells it,I think this is what TSC sells in 5 gallon buckets for parts washer solvent. Not quite as flammable as diesel,and washes off easily.
JHesler
04-16-2004 11:39:56
I use kerosene mixed with Kano Floway available at www.kanolabs.com
The Floway makes the kerosene rinse off with water.
old
04-16-2004 11:28:09
Some people use diesel or kerosine and they also make stuff just for them but it cost as much or more for it then the washer did. I was going to get a 20 gallion one till I found out how much it would cost to fill it. I needed something that would clean the parts so I could then paint them and diesel will not work for that.
