Tool Talk Discussion Forum
12 valve cummins turbo
ralph
04-16-2004 10:04:48
has anybody rebuilt a turbo-mine is leaking oil . how much is a seal kit and is it hard to do. thanks ralph
Charles (in GA)
04-16-2004 18:01:23
 Re: 12 valve cummins turbo in reply to ralph, 04-16-2004 10:04:48
Turbos turn at an unreal RPM and they are very sensitive to the least little out of balance or other problem. Even though they are probably expensive, a professionally rebuilt one is probably your best bet. Even if you were able to get it apart and back together sucessfully, I suspect it would self destruct shortly thereafter, leaving you without even a core to trade in.
Charles
Ray,IN
04-16-2004 20:37:33
 Re: Re: 12 valve cummins turbo in reply to Charles (in GA), 04-16-2004 18:01:23
Go to dieselram.com and talk to the bombers. They seem to have done just about everything possible under a shade tree.
Doug Gage
04-22-2004 12:55:23
 Re: Re: Re: 12 valve cummins turbo in reply to Ray,IN, 04-16-2004 20:37:33
I agree, don't try to rebuild the turbo yourself. You'll will probably end up with more damage.
Two things on my truck i won't attempt to fix...the turbo and fuel injection pump
