Tool Talk Discussion Forum
Think I fixed it
Dan Wa
04-16-2004 07:10:50
Posted message a few days ago about wand or "trigger gun" on pressure washer. The one I have is Karacher but Sears and some others seem to be similar. The shut off valve uses a ball, spring and nylon washer pressed in to hold it all. No parts available from company. I had ball and spring and small nylon washer from bottom but couldn't keep it together with snap ring. I taped the upper part where original nylon retainer was pressed in. Tapped for 1/2 nc. Cut about 5/16 off end of a bold and drilled hole in center and put cut across top to use screwdriver on it. Seems to work good to hold it together. In case someone else has had this problem. Email me if you need more info.
RexB
04-17-2004 15:49:12
 Re: Think I fixed it in reply to Dan Wa, 04-16-2004 07:10:50
Good fix-it job Dan Wa, the man'f couldn't do it so you re-engineered it. Outstanding!
RexB
