Tool Talk Discussion Forum
Shallow well pumps
Robert
04-15-2004 10:19:21
I've got a project going right now, and it involves mixing concrete at a site where there's no running water or electricity at the moment.
A buddy loaned me a small pump (1/3 hp), and, I have an electric mixer, along with a portable generator, that will run both.
My question is, will the pump develop enough suction to draw water out of a tank (pond)? The pump runs fine, but I can't tell there's much suction at either port. Does it have to be primed?
My buddy said he used it to pump water from his tank a couple of years ago, but couldn't remember the set-up.
Thanks in advance for any help!
Richard Pierce
04-26-2004 07:39:33
 Re: Shallow well pumps in reply to Robert, 04-15-2004 10:19:21
I have a shallow well pump with bladder tank,i have now have been losing water pressure,do these tanks need to have a certain amount of psi to maintain certain water pressure .
buickanddeere
04-15-2004 11:52:37
The max any pump will lift ar sea level is about 32' and eficiency will be just above 0%. A centrifical pump is rapidly loosing efficiency if lifting more than 15' and 20 is about max. A foot valve will be needed hold prime. If the pump is placed at the supply end and only has to lift a foot or two or is submersable. Then a typical simple single stage centrifical pump can easly push 65' to 130' up (30 to 60psi).
test
05-19-2004 20:53:02
 Re: Re: Shallow well pumps in reply to buickanddeere, 04-15-2004 11:52:37
test
