Tool Talk Discussion Forum
air pressure shut off on pancake
randy
04-14-2004 08:50:26
have a 2 hp pancake compressor, it is suppose to shut off a 115psi, it does not. I have to manually shut it off. How do I fix, I do not have a manual. It is a chicago electric purchased from harbor freight as XMAS gift. I am a weekend warrior that uses it for air nailing.
Thanks in advance.
jeff
04-14-2004 14:55:54
 Re: air pressure shut off on pancake in reply to randy, 04-14-2004 08:50:26
There is one more place that none of you has jumped. Is this an oiless pump? At work in one of the Atlantic city places we have huge pot washers that use these for raising the doors. They last about 1/2 a year and then we throw them out. I wanted to rebuild them but a $60.oo kit ain't worth it. I wouldn't give room to an oiless. All of my units are oil type and I use a filter when painting. If your pump is worn out it CAN"T pump high enough to shut off the switch. I would also advise that 100 lbs is high enough for oiless. The piston has a little teflon ring the gets pooped out. Any good local compressor place can order it up for you and they are not hard to work on. DO NOT clean the cylider; the coating of teflon will now make the new ring last longer! Jeff
Charles (in GA)
04-14-2004 13:16:40
The pressure switch and the manual shutoff are many times one in the same. If its a lever sticking out of a box like affair that the wires go into, it probably is the pressure switch also.
You might try unplugging it and removing the cover and observing the operation of the switch as you move the manual on/off lever and then try it plugged in and running (be careful, you are playing around hot electrical contacts when you do this... look, don't touch!!!) These pressure switchs/manual on/off boxes also relieve the head pressure on the compressor when they shut off so the compressor will start up the next time without a load. Because of this you cannot just buy a pressure switch anywhere.
If you figure out what it is, try calling their customer service number and explain the problem to them, being a fairly new unit you may be able to get fixed or replaced for free or little cost.
Charles
RZ(Wa)
04-14-2004 13:16:08
For either of my compressors and on the well pump, I've had to raise the contact plate and burnish the points. At different times I've used a burnishing tool or 400/600 grit aluminum oxide paper to clean them. Although this is more of an immediate repair, it will last awhile, keep in mind the perssure switch will need replacing in the near future. If you do clean them this way be sure to blow and wipe the residue for both the contactor plates. What is happening (most likely) is that the points are "welding" themselves together.
One one occasion, I've seen the spring at the rear of the contactor plates get out of position when someone dropped the compressor.
Chuck - WI
04-14-2004 12:05:13
Pressure switch problem .. most are right by your manual on/off ..... .. try porter-cable.com .. they have those 'types' of units (not that product) but you can check one of the online owners manual or parts list just for a feel of what you are looking at
gspig
04-14-2004 09:23:17
How electrically inclined are you? Your compressor is shut off by a pressure switch. You may be able to find it by following the power cord to the compressor motor. It may be a square box, but it will screw into the tank on one end and have two wires on the other. You may be able to clean the contacts on the switch or you may have to replace it.
old
04-14-2004 09:20:42
Sounds like a bad preasure shut off switch, you can buy them at a good hardware store.
mj
04-14-2004 10:18:31
 Re: Re: air pressure shut off on pancake in reply to old, 04-14-2004 09:20:42
Ditto on "sounds like a bad pressure switch".
