Tool Talk Discussion Forum
Craftsman 3 h.p. air compressor
zev
04-13-2004 19:39:40
I picked up a Craftsman 3 h.p., 20 gallon air compressor. Anyone know how to change the oil in the thing?
Charles (in GA)
04-14-2004 13:04:09
 Re: Craftsman 3 h.p. air compressor in reply to zev, 04-13-2004 19:39:40
Yes, if it is an oil type compressor, the fill and drain plugs will be readily apparent near the base of the unit. If you have a oil-less unit, you'll know it real quick, as you reach for the ear plugs. You can't stand to be in the same area with an oil-less compressor when its running, too LOUD!!!
Charles
MAC,IL
04-14-2004 06:52:56
I dont know the particular model number you have, but I have one and the oil plug is at the bottom(not on bottom) of the compressor opposite the flywheel. Seems it is a 3/8 pipe plug. I use compressor oil. Careful tho, you may have an oiless model. Might want to go to the sears parts web, type in the model number and read up on it.
