Tool Talk Discussion Forum
Tire question???
Trailer Puller
04-13-2004 04:27:13
Looking for some 8X14.5 tires I found some that have "8-14.5 LT and 8-14.5 LPT" on them,both are {12-PLY rated} I don't see "FOR MOBILE HOME USE" anywhere on them, what are these tires designed for?They are mounted on donut rims ,and look near new,what is a fair price? Thank you
JT
04-13-2004 23:09:05
 Re: Tire question??? in reply to Trailer Puller, 04-13-2004 04:27:13
Load range letters translate like this
A = 2 ply
B = 4 ply
C = 6 ply
and so on up to and including at least G.
I used to haul my toys on a heavy built bumper hitch with those 14.5's on donut rims. Had a pretty high attrition rate on the tires. Check your pressures before you leave on any trip. Still have the trailer for a water wagon it just doesn't get very far from home.
Most of the problems I had were thrown caps. Finally had one blow and that was the last time a tractor was on the trailer. If you have ever tried to change one of those donut rims on the road without a Impact wrench you know why I don't let it get away from home any more.
The tires we run I think are F's or G's and run about $100 + each for regular use. The trailer home tires were a cheaper version only had about 1/3 tread.
If you need them and they carry the higher ratings anything less that $100 you should buy as many as you can afford you will need them.
JM2CW
JT
dtanner
04-13-2004 22:28:19
I built a trailer 20 years ago with a mobile home axel. When I went to get new tires last year I found that the smaller tires are no longer made, and that a local business buying mobile home tires would sell me "good" used, next size larger, ones for $35 each. I made calls to people setting up manufactured homes and found the "tire" business. Good luck. dtanner
hjp
04-13-2004 21:18:02
the (LT) designation is ALOT different than a (P) RATING
THE TIRE IS OF A HARDER COMPOUND SO IT DOES NOT WERE OUT FAST UNDER THE RATED LOAD AND HANDLES HEAT BETTER DUE TO HIGHER WORKING LOADS AND ROAD FRICTION . HEAT IS ALSO GRADED AND LISTED ON THE SIDE WALL OF ALL TIRES USED FOR HIGHWAY USE.(E) IS THE HIGHEST (HEAVY) RATING AT CLOSE TO 2200LBS EACH TIRE.
PAY ATTENSION TO WHAT THE PLYS ARE MADE OF IE. STEEL BELTED VS NYLON,KEVLAR ECT. 12 PLY IN STEEL IS NOT 12 PLY IN NYLON
LAST/ TRAILER TIRES ARE BUILT DIFFERENTLY THAN TRUCK OR PASSENGER TIRES ,MOST TRAILER TIRES HANDLE SEVER LOADS AND SHOCKS/OCCILATIONS THAT ARE ABORBED BY THE TIRE NOT LIKE CARS AND TRUCKS THAT HAVE SHOCKS/SOFTER TIRES AND SPRINGS FOR A GIVEN LOAD CAPACITY
redrock
04-13-2004 19:53:01
I priced some of those a while back and the were between $65.00 and $85.00 depending on what load rating. My tire store has good, better and best tire brands available.The 12 ply's would work out pretty well. Mounted on rims and all probably go for $50.00 each.
john in la
04-13-2004 10:46:17
The letters behind the size of a tire such as LT designate it as a light truck tire. I pay no attention to this and recommend you do the same. The info you are interested in is 12 PLY rated. this would be a good tire. Another thing you should look for is the load rating of the tire. It is a letter and higher is better. If I remember correctly light truck are rated at C and some heavier trailers have tires rated D.
