Tool Talk Discussion Forum
lincoln sa200 welder question
dave
04-12-2004 05:34:39
i found a old lincoln gas welder i think it is a sa200 it has some sort of bellows for a governor. don't know anything about these. it doesn't run and i was wondering if these are worth fixing and using? and also can the governer system be updated?? any idea how old this thing is? thanks for the help
dave
Charles
04-12-2004 17:23:04
 Re: lincoln sa200 welder question in reply to dave, 04-12-2004 05:34:39
Very good welder you found.as for the bellows that is for the throtle control to idle when not welding. I have 3 of the welders and have been able to get parts for them.Also they only produce115 volts DC at the outlet.Only good for grinders, lights and non variable speed drills.
dave
04-15-2004 13:00:15
 Re: Re: lincoln sa200 welder question in reply to Charles, 04-12-2004 17:23:04
thanks for the help. i called lincoln and gave the guy the code #, he said the welder was built in 1955. i was wondering if the throttle control deal works ok or if it can be upgraded? i hope to try to get it running pretty quick, it doesn't look like there's a whole lot to it.
MetalZ
04-12-2004 20:06:14
Hi Dave
If that SA200 has a very large welding generator (about the size of a SAE400) it is one heck of a good machine. I have one with a Perkins 236-4 diesel and Lincoln denied ever making a SA200 with a 4-cyl. Perkins, the serial number made no sense to them. It was only after talking to an older fella that worked at Lincoln when it was built ('61-'63 as he remembered) that I found out anything about it. He told me to never sell it if I anticipated ever needing a portable welder as
my machine was "custom" made by Lincoln for extreme, super heavy duty service and only a few were built and Lincoln didn't keep many records of them. As far as the bellows is concerned, I haven't the faintest idea.
Hope this was at least interesting
MetalZ
OkieBill
04-12-2004 19:58:05
Charles, I just bought an SA200 which has an ailing range switch. Can you suggest a source for parts? Thanks!
KX
04-14-2004 09:08:24
 Re: Re: Re: lincoln sa200 welder question in reply to OkieBill, 04-12-2004 19:58:05
Applied Equipment Inc Dallas, TX 75201 (214) 630-9353
They work on SA-200 and all other welders and they have any part you need.
doug stockman
04-15-2004 02:51:28
 Re: Re: Re: Re: lincoln sa200 welder question in reply to KX, 04-14-2004 09:08:24
Thanks for the info. I just got an SA200 which is in pretty good working order. I am sure I will need replacement parts at some point.
Doug Stockman
Penfield, NY
OkieBill
04-14-2004 19:21:36
KX, Thank you for the info. It is appreciated!
Charles
04-13-2004 18:27:40
When I'm back at the shop I can get an addy for a parts place for welders.They would be located in NJ
