Tool Talk Discussion Forum
My Ebay buy of the month story -- Long post
Charles (in GA)
04-10-2004 17:21:29
I thought I'd tell a story of my "Ebay buy of the month".
When you fool with tractors, cars, trucks, and airplanes, among other things, you often find need for a press to force stuff apart or press in things such as bushings, bearing races in hubs, etc. I've always wanted a hydraulic press and I despise the cheapie stamped steel presses with the bottle jacks mounted in them and their wobbly mountings. At work we have a number of Dake brand presses and I have admired the quality of their construction and their design. One in particular interested me was an old 25 ton "H" model which I thought would be particularly suited to my needs.
Quite by chance I did some searches on Ebay and turned up a couple of the Dake 25 ton models. One interested me, it had a $50 starting bid (with a reserve, unknown to me at the time of course) and it was located in Edison, New Jersey, some 900 driving miles from me!!! The listing was lacking any description except that it was a "Drake" (misspelling of the manufacturer's name, Dake) and that it was a "10 ton". Dake never made a 10 ton in this design so I emailed their tech rep and asked him to look at the listing. He confirmed my suspicions that it really was my dream come true, 25 ton model. The pictures were poor and I emailed the seller to confirm it was in good working condition and not damaged or the frame bent, etc. He verified it was OK and I found out he was a middle man, listing it for someone who was not familiar enough with the internet or Ebay to want to list it themselves.
Anyhow, I waited and in the last hour, I made a $252 bid, enough I suspected for to beat the reserve, No one else had bid on it, probably due to the 10 ton description. Ebay showed me as the winner at the $150 reserve and when I got home that nite it showed me the winner at $191.38!!!
It seems that four SECONDS from the close of the bidding a $188.88 bid was received and I did not know it. I was still the high bidder but was "jacked up" by the last second bidder.
So soon after that I set out up I 85 and I 95 for Edison, NJ. I battled high winds on the road (scary when its blowing 40 mph and you are crossing a very high bridge over a river, and lots of traffic, but I arrived. We loaded it in the back of my Ranger. I had carefully planned it out and knew it would lay down in the bed with the gauge and the legs removed, with only about an inch to spare both in length and width. We set it on 4x4's laying down, using a strap and a boom and hook on a forklift. The seller and I chated for a few minutes in his office (I'm conviced he's the nicest guy in New Jersey, great fellow) and I reloaded the truck with my toolboxes and extra wood blocks and other items and reinstalled the camper shell, and set out South on the Jersey Turnpike. Numerous tolls, several traffic jams and a number of rest and wake up stops later I arrived back home.
1875 miles total drive, one nite in a motel and the gas and tolls, I still don't have over $500 in the press total including the purchase price. The only other ones I've found on Ebay were $649 starting bid and one in an Ebay store for $1250! Dake has made the press for probably 40 years or more and new it sells at MSC for $2750, the exact same unit. The Dake presses are hard to find used, everyone likes them alot and tends to keep them, when they do sell its word of mouth, most of the used equipment and machinery dealers don't want to mess with something as small as a 25 ton unit. In fact that is why this unit was on Ebay, it came from a chemical plant that was being closed down (sold overseas) and was used by the plant maintenance department. The seller told me the used machinery dealers wouldn't buy the press, drill press, and other small shop equipment, and that is why they resorted to Ebay.
The press was filthy dirty and I removed it from the truck with an engine hoist (it weighs 450 lbs) and pressure washed it and changed the oil, buying new, recommended oil for it from Grainger, and it works like a champ.
Gotta go, there's a bead blasting cabinet coming up for bid..... ..... .....
Charles
MarkB
04-12-2004 05:05:59
 Re: My Ebay buy of the month story -- Long post in reply to Charles (in GA), 04-10-2004 17:21:29
Thanks for sharing your experience. With all of the reports of crooks and swindlers on Ebay, it's nice to hear from someone who's had a good experience.
I'll add that I have had only good experiences on Ebay. My cardinal rule: Don't bid more than you can afford to lose!
Chuck UR
04-11-2004 11:40:17
I have a very slow dial up.
What I do is open 2 windows to the same auction.
As the clock ticks down I'll load my bid in one window and keep refreshing the other.
Then with seconds to go BAMMMM.
greg
04-10-2004 18:04:14
always nice to hear someone getting a good deal. i know what you mean about the cheapo presses. as i work in the demolition business, im currently collecting some I beams so i can build my own press.
Kevin
04-10-2004 17:49:14
Congrats on a great ebay buy.That bidding with 4 seconds to go is called "sniping". Get used to it! 95% of bids occur with less than 30 seconds in the auction, those of us without broadband have a hard time competing, so we have to go with a high bid earlier like you did. Even then sometimes a sniper hits a bid with less than two seconds and wins an auction at a price below your high bid!
Charles (in GA)
04-10-2004 18:39:50
 Re: Re: My Ebay buy of the month story -- Long pos in reply to Kevin, 04-10-2004 17:49:14
I have broadband at home and have been doing last second bidding myself, but I make the bid for what I am really willing to pay, the highest amount, allowing for what I will have to pay for shipping. I try to be fair to myself and others, not just jump in and throw in a lowball last second bid.
In the case of the press I had to bid early enough to see if I was going to meet a reserve or if it was set so high as to be unreasonable. I was on a T1 line at work and the connection is near instaneous.
I've suspected some of these last minute bidders that "jack up" my winning bids are auction shills (but I don't think so in the case of the press) and in other cases, its someone with just enough knowlege of Ebay to be dangerous and stupid. I bid last second many times, but I bid high, as high as I can feel comfortable with, and not just a little more over the last bid.
I've had a couple of cases where I bid say $78 on a starting bid of $50 and some fool jumps in and bids, $55, then a moment later $60, then something like $68 and quits, leaving me with a higher cost and them with nothing. They are "feeling" for my high bid.... its frustrating. Thats why I bid last second.
Charles
