Tool Talk Discussion Forum
kohler 18hp
kevin
04-09-2004 06:26:45
Starts and runs fine when cold, after about an hour, it will quit and not start, if left cool down it will back fire out the exhust and start. When hot again it will die. What gives?
Been there done that
04-11-2004 07:34:38
 Re: kohler 18hp in reply to kevin, 04-09-2004 06:26:45
My 15 hp worked like a champ on the riding mower and one day what you say happened. I'm a pretty fair mechanic so I applied my skilly and failed repeatedly. One day I was ready for it. I had the air cleaner off with a can of starting fluid in my hand when it started to die. I gave it a squirt and nothing happened.
Next day I bought a $42 magneto and no problems since. This mag has no points and no wires to it so when it quit (firing) there was nothing but it and the spark plug and the plug was new.
Good luck,
Mark (txblu)
Hermit
04-09-2004 19:15:36
If your motor has a low oil pressure switch connected with your ignition system, that may cause the problem. As engine heats up, the oil thins out and shuts off engine till it cools back down. Check pressure switch, oil weight and oil level.
George
04-09-2004 07:39:01
Two things:
Vapor Lock -- either the carburator or fuel lines are getting hot.
Magneto has a high temperature problem. (When you try to start the engine while hot, do you get spark? If so, vapor lock is probably the problem.)
kevin
04-09-2004 08:44:01
 Re: Re: kohler 18hp in reply to George, 04-09-2004 07:39:01
George, I don't get any spark, untill it's cooled off. I'm guessing the backfire is gas vapors in the muffler, that built up when it dies.
George
04-09-2004 09:46:07
 Re: Re: Re: kohler 18hp in reply to kevin, 04-09-2004 08:44:01
I would say your problem then is in the ignition. Does it have an automotive-type coil? Then either the condensor or the coil is temperature sensitive. If it has a solid state magneto, I believe you have to replace the whole thing.
Dean
04-09-2004 11:56:39
 Re: Re: Re: Re: kohler 18hp in reply to George, 04-09-2004 09:46:07
I believe George is correct about the ignition. If this is the Command series engines (Vee-twin/OHV), I'd suggest calling a Kohler dealer -- this may be covered under warrenty, even if the 2 years is up.
kevin
04-09-2004 12:05:33
 Re: Re: Re: Re: Re: kohler 18hp in reply to Dean, 04-09-2004 11:56:39
Thank's for the replies, it's a command series, but a 91 model
VaTom
04-09-2004 18:06:39
 Re: Re: Re: Re: Re: Re: kohler 18hp in reply to kevin, 04-09-2004 12:05:33
My Kohler problems were somewhat different. The dealer, after checking with Kohler, told me that the time line on the warranty was strictly adhered to. Problem was glue failure on the flywheel. I couldn't believe they wouldn't stand behind it, but they didn't.
kevin
04-09-2004 10:23:18
It has a mag on the flywheel, no coil. Kohler calls it a ign. modual.
George
04-09-2004 13:54:32
 Re: Re: Re: Re: Re: kohler 18hp in reply to kevin, 04-09-2004 10:23:18
If the ignition module is anything like other Kohler parts, bring lots of money.
kevin
04-12-2004 11:28:31
 Re: Re: Re: Re: Re: Re: kohler 18hp in reply to George, 04-09-2004 13:54:32
I'm going to replace the ign. mod. Will let you know if that was it.
