Tool Talk Discussion Forum
95 Dodge trans.
Bill
04-06-2004 23:47:54
I have a 95 Dodge 2500 w. 5.9 cummins auto transmission that sometimes wont stay in lock out converter ( hunts ) could somebody please help me with this problem ?
thanks Bill
db
04-08-2004 02:08:46
 Re: 95 Dodge trans. in reply to Bill, 04-06-2004 23:47:54
check all your grounds and make sure your batteries are clean also check out turbodieselregister.com
AZ Jack
04-07-2004 20:38:09
Are you saying it won't stay in lock out or won't stay locked up. Can't imagine why you would want it to stay out of lock up-that is when you get your best pulling torque. Under 45mph you should be in converter mode-unlocked (under 35 if your overdrive is locked out by the dash button). I somehow feel like when you say it is searching that it is going into converter when it shouldn't. On mine it was the throttle position sensor (about a $150 fix for part) easy to change yourself. Could also be the speed sensor. Let us know what you find-or if I am reading your question wrong-Jack
MAC,IL
04-07-2004 18:26:01
Bill: Check alldata.com It seems there was Maybe a TSB in 96 on that problem. You might see if there is anything that pertains to this there, if so, the dodge dealer should print out a copy of the TSB for you. Else let you read it. It should explain the fix.
Mark
04-07-2004 04:58:03
It can be a tps switch with dirty contacts or needs adjustment,bad speed sensor,brake light switch,or a wiring problem. Post back with some more info,speed it does it,loaded or empty etc.
Bill
04-07-2004 17:14:30
 Re: Re: 95 Dodge trans. in reply to Mark, 04-07-2004 04:58:03
Mark It does it around 70mph loaded is worse but I can go 2or 3 weeks and it will be good thats the problem it is intermitent right now it is real bad Iwant to try and isolate it but realy dont know how to go about it I thought it might be a generic problem thanks
Bill
