Tool Talk Discussion Forum
Wet sawing a asphalt driveway?
Rod M1
04-05-2004 10:10:58
Hi I have a project coming up that will involve Wet sawing a asphalt driveway. I would like to now how to make a line that wont wash way when I'm sawing? I don't think a chalk line will work what do you think? What do you suggest? Thanks
Rod M1
04-08-2004 08:41:13
 Re: Wet sawing a asphalt driveway? in reply to Rod M1, 04-05-2004 10:10:58
Thanks everyone!
mudstuck- why?
04-05-2004 15:25:50
Why wetsaw? We just sawed out a spot to patch with a Husqvarna 371 masonry saw. Worked like a charm and didn't cost a ton to rent.
JF
04-05-2004 19:19:34
 Re: Re: Wet sawing a asphalt driveway? in reply to mudstuck- why?, 04-05-2004 15:25:50
If you dry cut it,mark it ,score it,then go back and finish it off.Thats what we so at work.
Dave
04-05-2004 15:12:52
lay a string down and spray paint over it,, the line left by the string will show up good,,
also make sure you keep the Blade UP and OUT of the loose stone below the asphalt it you cut 75 % of the asphalt it will break clean,, the loose stone below can cause alot of blade damage and premature wear.
JF
04-05-2004 13:40:21
I would think if it is a wet saw it will come with a guide, so use a string line.Offset it.
buck
04-05-2004 11:50:36
Laser- even one of the pencil pointer types will do.
