Tool Talk Discussion Forum
ryobi 4 cycle weed whacker?
Chris Brown
04-04-2004 08:29:18
third party image
I am thinking on buying a 4 cycle ryobi and want your all's opinion on the 4 cycle engine. Are they any good? I'm one of those guys that runs a weed eater till theres nothing left of it.I don't go out every 2 or 3 years and just get a new one. The sears I an replacing I bought back in 93 and I have nursed all the life out of it I can get. Thanks for any replies
fzbcheve
04-07-2004 19:33:50
 Re: ryobi 4 cycle weed whacker? in reply to Chris Brown, 04-04-2004 08:29:18
before yoy buy any unit, check and see the usable hours it is built for.
Most of the Ryobi units use only one piston ring and are rated at 50 hours of life. OK for Joe average home owner.
Mike M
04-04-2004 17:31:57
My dad has one and loves it.Also uses a lot less gas. I have also seen a Honda 4 cycle advertised at Home Depot I think.Maybe Lowes ?
Mark
04-04-2004 14:00:10
I would stick to the 2 cycle version if you can get one. The 4 strokes have trap doors in the crankcase that is SUPPOSED to hold the oil where it should be.They don't always work and the result is a tied up engine.The 2 strokes will last 10-20 years with reasonable care,take less maintenance,have a wider power band,and can be run in any position without worrying. Stick to the brands that last like Stihl,or Echo if it will be used hard,the ryobi's are joe homeowner disposables (junk)
jim
04-04-2004 13:20:02
if your are a homeowner and replacing a trimmer that is 9 years old, ya did not get a lot of use out of it. You get what you pay for. you can spend $250.-$270. and get a good trimmer that will last for as long as you want o use one, I have a trimmer that must be 20 years old and runs like a raped ape. and I did not have to nurse it, put good gas in it and use it, new plug every year. Does the palce you are buying it from offer warranty servie if you have a problem or does it have to be sent somewhere to work on it. Lack of service is the main reason I would not ever buy a Ryobi. I had had parts ordered for them in the past that took a month to get.
Chris
04-04-2004 13:33:49
 Re: Re: ryobi 4 cycle weed whacker? in reply to jim, 04-04-2004 13:20:02
I keep 4 yards and sometimes a cemetary. Theres no telling how many hours are on the $99 sears .
John *.?-!.* cub owner
04-04-2004 13:19:59
Never had any dealings with the 4 cycle, but have owned one of the bigger 2 cycles for about 4 years (Click Link), and have been well satisfied with it.
Bguy
04-04-2004 09:20:54
I have 2, 1 is going on 4 yrs old and the other 2 yrs old with a brush cutter blade, my father in law has 1 about 3 yrs old and they have all been good units with no problems. We love them.
