Tool Talk Discussion Forum
Broken Brush hog Blade
PJ
04-02-2004 21:28:25
I've loooked in the archives but couldn't find the answer, so maybe it is a dumb question to begin with. Here goes.
While happilly hoggin away with my 9N recently, I felt more than heard that gut wrenching, bone jangling jolt that said: "something is majorly wrong here". Turns out that one of the cutters glanced a hidden outcrop of a Granite and busted.
Now the question; is it possible to weld the thing back together. It'd be lots easier to do this than to shell out a bundle for new blades and then wrestle the old ones off.
Thanks for the help.
Dieselrider
04-04-2004 07:48:01
 Re: Broken Brush hog Blade in reply to PJ, 04-02-2004 21:28:25
PJ, what if the thing lets go again and comes through a tire or a casting on the tractor, or worst of all hits you or someone else? You may save a few dollars now and spend alot more later. The chances of it happening are one heck of alot better than you winning the lottery ever.
DaveJWI
04-04-2004 07:45:13
I had a cousin who broke a blade on his brush hog. Because he needed the mower and was having trouble finding blades he welded the blade back together. Still vibrated a little due to balance being off a bit, but was usuable. Had to put on new blades anyway, as he hit another rock and blade broke again. Cost him $150 for the two new blades from the dealer. Only place he could find them.
wh
04-03-2004 14:23:29
yes - IF you follow the following directions. 1 - vee out blade where you plan to weld.
2 - use a 7018 rod
3 - follow all reccomended procedures for 7018 rods
4 - let cool slowly before installing
5 - MOST IMPORTANT - take out additional 10 million $ insurance policy - you will need it!!!!BLADES ARE CHEAP - buy new blades!!!
hay
04-03-2004 11:11:09
i know i would not weld a broken blade, but i have a friend that done his and so far it is ok. however, blades are really not expensive considering the fact that if a weld breaks, someone could get seriously injured or killed.
Bus Driver
04-03-2004 10:15:35
Mine broke and the piece went through the side of the mower, tore a hole- 11 gage steel- and traveled 40 feet more before landing. Never would I consider welding a broken blade.
markct
04-03-2004 09:50:45
well i wouldnt recomend it, but i will admit that once i did weld an old for mower blade back together, the end broke off about 6 inches long, so i veed it out good and welded it with 7018, i was kinda nervous about it but needed to get mowing done and i am always very careful to make sure no one is in the area when brushogging, well about 3 months later i was using the mower and there was a huge bang and a the mower started shaking violently so i figured the end i welded on broke off, so i took the mower back to the shop, bought new blades and started to install them, when taking the old ones off i realized that the one i had welded before was not the one that broke this time! so they can be welded and welded well, but i think its alot of luck to get them to hold, and blades are pretty cheap realy so i wouldnt recomend welding them, just go buy a new set, they take a real beating
Jerry/MT
04-03-2004 08:37:13
What ever you do, don't weld a broken mower blade! They're cheap enough ($20 a piece) and the risk of a serious injury or a fatality is so high that it's not worth it. I'm not even a fan of sharpening them. They should be replaced on regular basis. They can get fatigue cracks in them and that, coupled with the abuse they take, can lead to a catatrophic failure. For safety's sake just buy some replacement blades
mike
04-03-2004 08:31:22
I'm with tbone it can be done BUT it is not a good idea that piece comes off like a bullet (only alot heavier)and you never know where it is going to go (been there done that)around here new ones are only about 20$apiece good luck in whatever you do. mike
T_Bone
04-03-2004 07:45:22
Hi PJ,
Can it be done? Yes
Would I do recomend it? NO
To many safety related issues. You'll also notice I never tell anyone how to weld a fuel tank or how too wire there shop. These are not internet topics for repair advice.
T_Bone
Delbert
04-03-2004 07:36:01
I broke one and welded it back so far so good but would go for new if I could find them.
rhudson
04-02-2004 21:43:33
i don't think i would weld one for anyone, especially for my own use. but i worry about such things. i would feel better about new set of blades and bolts.
