Tool Talk Discussion Forum
Odd threads... Die needed
Bob
04-02-2004 11:52:08
I need to chase the threads on a truck front wheel spindle. It's 1970 vintage, and seems to be exactly 20TPI, so I doubt it's metric. The OD of the threads and the OD of the unthreaded area next to the threads is .841".
The closest die I can locate is 7/8", 20TPI, NSS.
Does that sound right? I think the die would be a bit oversized, but it is a split, adjustable die, so maybe it will work. Can anyone advise?
Art
04-06-2004 11:13:25
 Re: Odd threads... Die needed in reply to Bob, 04-02-2004 11:52:08
North-American Tool shows part# 13268 as 13/16-20 round die w/ 2"O.D. Call them @ 18008728277 and ask for the distributor closest to you.
Slowpoke
04-05-2004 20:40:48
Search for 'Airgas'. They used to have a lot of odd size taps & dies. Not cheap, tho. Try a thread restore file. They have 8 different sizes per file, two US files plus metric, about $10 ea. Available at Airgas & others.
20 tpi is one of the sizes.
Bob
04-02-2004 22:08:10
Thanks to all who took the time to reply.
Someone on another board posted that Harbor Freight has a set of 8 chasers for various spindle nut threads including the one I need, for $9.99. For that price I don't expect too much, but I hope it will do the job! I'm going to call a Harbor Freight outlet in the morning that is within driving distance to see if they carry the set, otherwise I'll order it from their website.
(Harbor Freight # 44486)
wdTom
04-02-2004 19:14:57
If you decide you really need a die and can't find one try MSC. They have a good selection of "special" threading tools.
KURT (mi)
04-02-2004 17:00:19
Looking in the machinery handbook I see a 13/16 - 20 thread, WHich is a .812 OD. Hope this helps, good luck finding a die of that size. Call a cutting tool distrubutor.
Ol Chief
04-02-2004 13:23:01
Check with Snap On,Owatonna Tool Co. Mac Tools and maybe Grainger.Several companies make a universal thread restore tool with changable die plates.I have owned a Snap On for over 40 years and has saved me lots of problems. Mine has a range of threads from 32 tpi to7-1/2tpi.The 7.5 was optional and I used it to repair damaged threads on Nat.Std fire hose couplings.Works very well for me.
Rod (NH)
04-02-2004 12:58:02
Hi Bob,
Have you considered the possibility of using a thread restorer file? I have found them quite handy if I don't have the correct size die and the threads are not buggered too bad. Usually a lot cheaper than a "special size" die.
third party image Rod
