Tool Talk Discussion Forum
Diesel engine RPM
Scott
04-02-2004 10:00:57
Hi,
I need to find a "Fuel Pulse" tach for a job I am working on. Does anyone know where this can be found? I need to use it with various pieces of equipment, so a variety would help.
Thanks,
Scott
Bill
04-04-2004 14:25:02
 Re: Diesel engine RPM in reply to Scott, 04-02-2004 10:00:57
Wow...clamp on tach for fuel injector lines...I guess I live in the dark ages... Do they make a clamp on the injector line unit for timing?
T_Bone
04-03-2004 07:33:41
Hi scott,
I have UEI digital photoelectric tach for my DVM, $110 from Johnstone Supply. Does upto 20000rpm and you calibrate by strobing a fluorescent lite at 7000rpm.
Only draw back it uses reflective tape for a strobing source and that means equipment shut down to attach the tape which was not always easy to do.
T_Bone
DaveCA
04-02-2004 16:59:09
I have used this one, works fine. Works on diesels with exposed inj lines and spark ign too. It will read spark voltage too.
Paul
04-02-2004 12:53:09
Scott, Take a look at www.tinytach.com. They have a handheld tach that the transducer clamps onto an injector line to read rpm. Model TT-220 works only on diesel engines, the other on both gas and diesel when you have both pickups.
Paul
Bob
04-02-2004 10:36:26
I believe Snap-On and MAC tools have them. They come up on ebay from time to time.
