Tool Talk Discussion Forum
Mac chainsaw parts needed.
Mike D
04-01-2004 18:24:28
Got no spark in my Mac Pro 510 limbing saw. Who can I get parts from?
Rob
04-02-2004 17:50:21
 Re: Mac chainsaw parts needed. in reply to Mike D, 04-01-2004 18:24:28
I'd try Randy Duncan on Ebay, He has parts for lots of things I didnt even KNOW there still were parts for. His ebay id is randysenginerepair
Mike D.
04-03-2004 06:22:24
 Re: Re: Mac chainsaw parts needed. in reply to Rob, 04-02-2004 17:50:21
Thanks Rob- I'll check him out.
jeff
04-01-2004 23:03:15
Before you start shootin hold on one. The 510 saws that I have are points type units. Remove the recoil and air filter cover and then you need to remove the flywheel. Right hand normal thread if I remember correctly. Under there is a little cover plate and inside are the points. Wash them clean with a little carbclean. Gas leaves a residue. Relube the cam surface with a TINY amount of bearing greese. It needs to be sticky to stay on. These saws have a real hot spark when everything is fine. Plugs can go bad too. Of all the saws I have not one had an ignition problem of any big deal. Let me know. Jeff
Mike D.
04-02-2004 13:20:51
 Re: Re: Mac chainsaw parts needed. in reply to jeff, 04-01-2004 23:03:15
Thanks a ton. How hard is that flywheel to get off? Any trick?
jeff
04-02-2004 22:30:53
 Re: Re: Re: Mac chainsaw parts needed. in reply to Mike D., 04-02-2004 13:20:51
No just lock the wheel with a big screwdriver, AND DON"T bust off a colling fin. The wheel has a TINY LITTLE BITTY KEY ! With the nut loose and back it off alittle. Next take a flat blade driver, put it under the wheel, NOT WHERE THE MAGNETS ARE, and give it a little twist. It should pop right off. Don't lift up on tools inside a saw cause it can punch a hole. Let me know how it went. Jeff
Mike D.
04-03-2004 06:21:29
 Re: Re: Re: Re: Mac chainsaw parts needed. in reply to jeff, 04-02-2004 22:30:53
Right as rain Jeff. Came off just as you described. Condenser is oil soaked by the look of it. The points look dry and are not pitted. I hope to clean everything up good this weekend. Then I'll reassemble it and see if we got spark. Sure appreciate your help- Mike in Va.
Joe (Wa)
04-01-2004 19:04:41
Maybe one of these vendors is in your area.
nice list
04-02-2004 13:49:32
 Re: Re: Mac chainsaw parts needed. in reply to Joe (Wa), 04-01-2004 19:04:41
That might be a big help. I've got some saws that need parts. Mike D.
