Tool Talk Discussion Forum
Multiquip Generator/Welder
RustyHulk
04-01-2004 12:06:44
I found (and bought) a used Multiquip WhisperWeld unit, trailer-mounted. Has a 3-cylinder Isuzu diesel engine and is a very good running low hour machine. Generator (8500 watts) works great, but the welder side doesn�t work at all. Nearest dealer is in Portland, Oregon, 85 miles away, a long way to tow it. Local electrical shop doesn�t have any ideas, except he thinks maybe a thermistor(?) is burned out. Does anyone know of a common problem, most probable cause, or even a WAG? If I could point the local guy in the right direction with a schematic or trouble-shooting list, he might be able to fix it at his shop (5 miles). Appreciate any help!
WAG
04-02-2004 09:23:29
 Re: Multiquip Generator/Welder in reply to RustyHulk, 04-01-2004 12:06:44
Know nothing about yours, but my miller Bobcat has lost output a couple times and it turned out to be a dirty connection on a Variable resistor. The resistor is 5-6" long and has a wire clamped on it about mid way. It will get a little rusty from condensation over time and loose contact. However I loose everything (ac and weld). Might want to check connections and see if anything is not makin contact.
check the inside of the
04-01-2004 19:33:58
welder cover for a schematic. If not call dealer to get one.
