Tool Talk Discussion Forum
Sand blaster
Jim E in cent I
03-30-2004 17:52:20
I have just bought a sand blaster. I will use it outside most of the time. What precautions should I take when using it. I know about eye protection.
Bill
04-04-2004 14:34:50
 Re: Sand blaster in reply to Jim E in cent IL, 03-30-2004 17:52:20
One more off the wall safety item- Just finished blasting a tractor in the driveway with Black Beauty blast material. There was a lot of it.... Friend drove up on his brand new motorcycle he came over to show me.... Seems blast material is slippery/friend & bike went down. Boy did all that abrasive material on the driveway surface do it's job on him & the new bike...Oh yeah... Boy was he UNHAPPY.....
Mel in sw Iowa
03-31-2004 20:42:30
1)Don't even think about blasting without a filtered air supply full face helmet and sleeves
such as those built by Bullard or 3M specifically for sandblasting. Do an internet search on Google or other search engine for "sandblasting" and "silicosis" to find out why. Learn as much as you can about the health risk before you ever crank your blaster up.
2)Don't blast with Silica Sand even if somebody gives it to you. There are many safer blasting media available.
Everything else is optional depending on the size of the job and the depth of your checkbook.
Harley
03-31-2004 17:32:11
I run an industrial blaster for the guy that is starting up check with local motor cycle paint shops, blasting skins and frames are big. I have done a few for a shop thay charged around $125.00 for a frame! I blast for people at the shop and charge a coffeee (.50) As for safty, goggles are a must. I use the white paper sutes, dust mask, duct tape, spats, and have a helmit with an air supply. Try to get small goggles that fit under the hood. Also get a good fit between the dust mask and the goggles.
Harley
03-31-2004 17:34:54
 Re: Re: Sand blaster in reply to Harley, 03-31-2004 17:32:11
I can see i need a speel checker (or go back 2 school)
Brian
03-31-2004 12:14:44
I use walnut shells to blast aluminum. Does anyone sell screens to sift and reclaim the shells? I have not found anything in my area. I lay down a tarp and catch the grit. Thanks
Vern-MI
03-31-2004 08:35:48
I'm going to suggest foam earplugs to keep both the noise and sand out of your ears. That stuff will find its way through any woven fabric you are wearing. You will notice that you are very dirty under your clothes after using your sandblaster. Expect that you will have sand in your teeth as well. Have fun!
John *.?-!.* cub owner
03-31-2004 06:46:40
Give some serious thought to the media you are going to use. Silica (white) sand is the most common, but the dust is a carcenogin. Check with the suppliers that provide material to your local auto parts stores for alternatives. You can get respirators, etc. at www.northernsafety.com. I have a hood, and wear a rain poncho ($7.95 at Walmart) to help keep the sand out of my clothes. Also long sleeves, and wear an old pair of long cuff welding gloves. That stuff stings if you aren't careful or if it bounces back.
Slowpoke
03-31-2004 00:33:49
For any thing more than occasional, short time use, it is recommended that one use a supplied air hood for breathing. Unfortunatly, most people don't use it because of the high cost. I am not aware of any cartrige respirators for use with abrasive blasting.
Wayne
03-30-2004 20:26:24
Hey Jim, your right about the eye protection, that's definately a priority item. That being said make sure your wearing a pair of full googgles, not just safety glasses. If you have a pair of vented goggles make sure they are the kind with the shielded vents and not just the open holes as the sand will find it's way through the vent holes if they aren't shielded in some way. You should also wear a good quality respirator of some type to keep from breathing the dust generated from the media as well as the paint and rust that the blasting process generates. Depending on how big the blaster is you may also need to wear at the very least a long sleeve shirt and a heavy pair of gloves. I have a big industrial blaster I use and with it I always wear a pair of coveralls taped at the wrist and ankles to keep the sand out of my other clothes. That's one thing you'll find when your blasting, the sand will find it's way into your pockets, wallet, etc. basically anywhere there is a place it can get, it will get.... Hope this helps and have fun with your new blaster.
Steve NE
03-31-2004 10:11:06
 Re: Re: Sand blaster in reply to Wayne, 03-30-2004 20:26:24
Hey, Wayne I have a brother that just bought a big industrial blaster... looking to start a small business with it. Do you hire out and what rates do you charge if so. What kinda work do you do with it and do you have any pointers I could let him know of. He has a couple of body shops lined to do work for but would like to explore his options.
anything would be of help
Thanks Steve
Wayne
03-31-2004 22:58:13
 Re: Re: Re: Sand blaster in reply to Steve NE, 03-31-2004 10:11:06
Hey Steve, most, but not all of the blasting I do is just side work for me. I've done alot of different things from blasting a complete Koering 405 crane (plus priming and painting), several trucks, some antique gas pumps, as well as other stuff in between. I normally charge in the $45 hr range plus the cost of the sand, but that varies with the job. Like if somebody has something fairely small they want done and isn't in a real rush I'll work it in and do it at the same time as something larger and just do it for a set price. If your brother is gonna be blasting as a business I'd suggest he explore the other media types beyond simply using sand. All I've ever really needed is sand for the stuff I've done but I know there are different media types you can use to obtain different finished results. With doing work for a body shop things like using a media ( either plastic or walnut shells, I believe) that doesn't cut bondo may be something they will want him to do. Doing this type of "media" blasting the cost of materials can get rather high. I know Blast-it-All makes a blasting booth that both reduces the dust released into the air as well as allowing you to reclaim and reuse the media. For somebody like me it wouldn't be economical to get a booth, but for somebody doing it full time it wouldn't take long to pay for itself, as well as keeping the EPA off his back for "contaminating the air". Typically I use a BX-12 grade sand if I'm doing a piece with extremely heavy layers of paint, a badly rusted frame, or something where I just want a fast removal time. The main thing with the 12 is it does leave a fairely rough finish on the piece, but it's still not anything a good fill and sand primer won't take care of. If the piece doesn't have as much paint or rust buildup or I just need a smoother finish I'll use a BX-30 grade sand. It doesn't cut quite as fast, but for doing things like the truck bodies and the antique pump skins I've done, it does a pretty good job. When he's figuring the amout of sand for a job, it typically takes about 1/3 more of the 30 to do the same amount of work as the 12. Too tell him if he figures it'll take 10 bags to do a job get 15 because it never fails to take more than you think. If you ever run out on a weekend and there is no blasting sand available,prime what you've done and wait until Monday, DON'T hit Home Depot and get play sand.....it has clay in it and will screw up the finish where it can't be painted until it's blasted clean again...voice of experience there, that was my first and last mistake with play sand..... When blasting sheet metal panels always keep the nozzel moving, don't linger in one spot too long or the heat it generates will warp the piece. This includes small individual panels (like the gas pump sides) as well as car tops, body panels, etc. Beyond that I don't really know of any other "tricks" to pass along. The main thing is do a good quality job and do it for a fair price and people will always come back. I'll put you as link to Blast-it-All so you can see what all they have to offer in the way of media types, etc. Tell your brother to have fun with his new blaster, and good luck with the new business Wayne
Ryan
03-31-2004 11:21:28
I have a gardener denver powered by a 471 detroit. I bought a respirator through gemplers and then wear eye protection on top of that. I notice I do not smell paint or other fine aersols through the filters I bought (replaceable). I also use ear plugs as it is very loud and hard on the ears. I would recommend a higher grade media if you can afford it. Sand is especially dirty, bounces more than slag, and does little for rust (works best taking paint). I have heard rates of 1.00 per minute on sandblasting.
Ryan
