Tool Talk Discussion Forum
Welding on chrome plated pipe
Matt B
03-30-2004 08:36:18
I need to attach a mounting flange on a piece of 3.5" chrome pipe in order to bolt it to my JD G for an exhaust stack. Can I simply grind off the crome at the end where I need to weld, or should I try to come up with a different way of attaching the pipe to the bolt flange?
Thanks, Matt
Dave Thomure
03-30-2004 19:39:38
 Re: Welding on chrome plated pipe in reply to Matt B, 03-30-2004 08:36:18
no need to grind the chrome IF you use a wire welder. this is what i do every day in our business Thomure Mfg. Co. We also make these stacks and if you have any ? please call me tomorrow at 1-800 527-9954 Hope this helps.Dave Thomure
T_Bone
03-30-2004 18:53:45
Hi Matt,
This is a wild guess as chrome metals very wildly in the composistion make-up. I would use Oxy/Acet with 15% silver filler rod using a borax/alcohol paste flux. Preclean is very important to remove oxidation but not necessary to remove the chrome(?).
I would use a low/mid flame holding 75% of the heat on the heavier piece. This should take about 10 minutes or so to preheat with a neutral flame before adding filler rod.
15% silver solder takes viberation extreamly well in a tight joint design.
T_Bone
Bob
03-30-2004 15:24:10
I beleive inhaling the fumes given off by welding chrome, or the metallic dust given off by grinding chrome are harmful. If you're going to weld it, at the very least, have GOOD ventilation, and if you're going to grind it, wear an approved respirator. Better to be safe than sorry.
old
03-30-2004 09:29:50
You can weld it on with out grinding off the crome but of course you will burn the crome on the pipe some but other then that its ok. Crome welds well by the way
Matt B
03-30-2004 18:12:43
 Re: Re: Welding on chrome plated pipe in reply to old, 03-30-2004 09:29:50
Thanks, I will give this a shot, maybe I can practice on some chromed handel bars from a mower or something to get a feel for it.
Matt
