Tool Talk Discussion Forum
kids barrell trailer
shoot
03-29-2004 09:32:23
I'm looking for plans or a picture of a trailer made out of a 55 gal drum to pull behind a lawn mover or 4 wheeler. It has a seat and steering wheel and I've seen several hooked together to form a train. Thanks for any help in this, it will be for the grandkids.
Larry_IN
03-30-2004 10:39:56
 Re: kids barrell trailer in reply to shoot, 03-29-2004 09:32:23
Looks like it would be expensive but I saw one that used hand Trucks/2 wheeled dolly? whatever they are called. for the entire chassis. They were hooked together in a train.
Larry on CO
03-29-2004 16:09:29
Here is a picture of a barrel train used by our club here in Co. I know it's not a real close-up, but maybe it will help you. Larry
shoot
03-29-2004 20:42:26
 Re: Re: kids barrell trailer in reply to Larry on CO, 03-29-2004 16:09:29
Thanks Larry for the picture, that helps.
JMS/MN
03-29-2004 11:26:00
Don't really need much for plans. Just put a kid on a barrel and use him as a pattern to torch out the required size hole. Cover the cut edge with a split water hose held in place with conduit clamps. Before cutting, rotate the barrel so a bung hole is at the bottom- for drainage in case the train is stored outside. Or if you left the kid on the barrel during cutting- instead of using a CHALK OUTLINE!.
RWK in WI
03-29-2004 18:03:50
 Re: Re: kids barrell trailer in reply to JMS/MN, 03-29-2004 11:26:00
Plastic barrels don't have sharp edges and don't rust. They are also easy to cut.
JMS/MN
03-29-2004 11:10:50
Check FARMSHOW magazine archives. They have had articles about that.
