Tool Talk Discussion Forum
Mac 3200 chainsaw
C. rafferty
03-27-2004 06:55:34
Help! bought this used with no manual. How do I adjust the chain?
Mac
03-27-2004 10:42:07
 Re: Mac 3200 chainsaw in reply to C. rafferty, 03-27-2004 06:55:34
If it's like the most of them, there should be 2 retaining nuts at the driven end of the chain, loosen and tighten chain with the screw.
greenbeanman
03-30-2004 08:41:57
 Re: Re: Mac 3200 chainsaw in reply to Mac, 03-27-2004 10:42:07
Loosen the nut on the side that is holding the bar. Tucked in next to the housing is an adjustment screw that runs parallel to the bar. A lug around the screw fits into a hole in the bar to move it. Turning the screw will move the entire bar to the desired tension, then retighten the bar nut.
While the bar nut is loose you may just want to go ahead and take the bar off so that you can make sure that the chain oiling port is free of sawdust. With the bar off you can see the lug of the adjustment screw.
WMMM
03-19-2006 11:25:03
 Re: Re: Re: Mac 3200 chainsaw in reply to greenbeanman, 03-30-2004 08:41:57
wharw do i get parts for the 3200 I from Ky.
No Hope
Raymond Holden
06-13-2006 20:53:55
 Re: Re: Re: Mac 3200 chainsaw in reply to WMMM, 03-19-2006 11:25:03
Link
cookie rogers
07-10-2006 07:57:19
 Re: Re: Re: Mac 3200 chainsaw in reply to Raymond Holden, 06-13-2006 20:53:55
I would like to get the manual for my grandfather
would you have onefor the mac 3200.
thank you,
Cookie
gecko76
09-28-2006 04:34:50
 Re: Re: Re: Mac 3200 chainsaw in reply to cookie rogers, 07-10-2006 07:57:19
Cookie;
Did you ever get the manual. I have an owners manual. I can copy and send it out if you still need. I am personally looking for a service manual for the MAC3200!!!!!
Let me know.
Fred
Bruce Miller
06-26-2007 10:20:22
 Mac 3200 chainsaw in reply to gecko76, 09-28-2006 04:34:50
Does anyone have instructions on how to remove and replace the oil tank on the MAC 3200 chainsaw? Thanks.
