Tool Talk Discussion Forum
Right Angle Drill - add on or dedicated
DumOleBob
03-26-2004 08:31:07
A couple of times a year I need to drill holes in tight places - as requiring a right angle drill. Are those right angle add on attachments any good? I've got electric, battery & air drills.
Or should a guy just get a dedicated right angle drill for only a couple of holes?
Doug D.
03-27-2004 18:33:17
 Re: Right Angle Drill - add on or dedicated in reply to DumOleBob, 03-26-2004 08:31:07
Years ago when I wanted a 1/2" chuck drill with alot of function that would last me a lifetime .... I bought a Milwaukee Electric. It was variable speed, 850 max Rpm, plenty of torq, and came in a right angle kit. Basically it is the smallest 1/2" drill Milwaukee makes that takes the right angle attachment. the right angle attachment gears it down to 650 max rpm. I get alot of use out of that 1/2" drill, and pop on the right angle attment when needed.
Dave K (IN)
03-29-2004 18:20:40
 Re: Re: Right Angle Drill - add on or dedicated in reply to Doug D., 03-27-2004 18:33:17
The Milwalkee is a fine drill. The angle drive will give you two speeds depending on which direction you install it. I have a couple that are over 15 years old and used daily.
Also, reference to Tom's post below, when you drill studs for wire pulling use an auger bit, not a speed bore. The RA drives don't spin fast enough for a speed bore and the torque will smash your hand when they bind.
James in MO
03-27-2004 10:05:41
I have a 1/4" right angle air drill and I use it once a year maybe but when I need it it has paid for itself numerous times over I can't remember what I gave for it but it seems like 60 or 70 dollars.
mj
03-26-2004 15:26:29
I bought an add-on from Harbor Freight several years ago and it's seen hard duty but still works fine. All metal construction, ball bearings and a 3/8 Jacobs� chuck. It was normally about $25 but goes on sale at random for $12.95. I think it's on sale now as a matter of fact.
Tom in TN
03-26-2004 12:46:22
Bob,
I installed central heat and air in my old farmhouse a few years ago. I bought an "add-on" right angle drill attachment to use to drill pilot holes in the duct work so I could insert metal screws. It was absolutely perfect for getting into restricted areas. It cost about $25 and was worth every penny of it.
However, since I am an idiot, I then used the attachment to drill some holes in some studs that I wanted to run electrical wire through. It worked marvelously on about a dozen holes, then the spade bit that I was using to drill the holes hung on the edge of a hole and stripped the gears inside the attachment.
I contacted the maker of the attachment and found out that they would send me a new set of gears for about $25 plus shipping and handling. I still have my broken attachment in the bottom of a tool box, but I wouldn't hesitate to buy another new one if I needed to do some light drilling in a restricted area.
Good luck,
Tom in TN
Mark
03-26-2004 20:34:48
 Re: Re: Right Angle Drill - add on or dedicated in reply to Tom in TN, 03-26-2004 12:46:22
I have the Makita 9.6V right angle drill. It's a great tool. But like every one has said it is a part time tool. I have had to replace the battery due to infrequent use. If I had to do it over I would by a corded right angle drill.
