Tool Talk Discussion Forum
Splined shaft
Earl S.
03-24-2004 15:43:42
We have a shaft that is 1.875 dia. 10 splines. Splines are worn looks to be 3/16-.1875 wide in the btm. The sides look to be tapered. I looked in the ENCO cat. All the cutters look to be straight like woodruff cutter. Does this take a special cutter, what is it called?? Thank You. Earl
buickanddeere
03-25-2004 15:31:44
 Re: Splined shaft in reply to Earl S., 03-24-2004 15:43:42
See page 65 of the March issue of Green Magazine. Moreland Crankshaft and Machine. 504 North St. Easton MD 21601 410-822-2500
Davis In SC
03-24-2004 18:26:08
Many splined shafts are cut on a Barber-Coleman Gear hobber, using a complex set-up. There are special formed cutters available to cut splines on a horizonal milling machine, but they are very expensive.
Earl S.
03-24-2004 19:08:53
 Re: Re: Splined shaft in reply to Davis In SC, 03-24-2004 18:26:08
Thanks that really helps. Earl
kraigWY
03-24-2004 17:39:46
I had to build a splined shaft that I couldn't find a cutter for. I ground a lathe bit to fit and used a fly cutter to make the splines. It was slow but it worked great.
Earl S.
03-24-2004 19:12:02
 Re: Re: Splined shaft in reply to kraigWY, 03-24-2004 17:39:46
Thanks for the help. Earl
Wayne
03-24-2004 16:25:49
It would probably take a cutter that was custom shaped to do them. We have a small machine shop setup but have never gotten into cutting splines ourself. Usually the place we take them to has to grind a milling cutter to match whatever the spline profile happens to be. If you think about say a 4" shaft with 10 splines, it's gonna have a different profile than a 1" shaft with 10 splines. This would hold true for whatever shaft size and spline combination you happen to run up on, so to have a generic cutter to do all different splnes would be almost impossible to do. Some splines arn't milled, their cut with a shaper, but even so the same thing would apply, you'd have to have the shapers cutting tool ground to obtain the correct profile on the spline.
Earl S.
03-24-2004 19:19:54
 Re: Re: Splined shaft in reply to Wayne, 03-24-2004 16:25:49
Thanks for the reply. We are trying to repair the splines on the stub shaft on a GP Deere rear drive where the small drive sprocket mounts. It is just held on shaft with snap ring so it has about 1/3 spline worn away. Earl
Davis In SC
03-24-2004 20:03:01
 Re: Re: Re: Splined shaft in reply to Earl S., 03-24-2004 19:19:54
Earl, if there is room to let the wheel run out, you could get a machine shop to grind the splines after welding. Bad thing is ,unless you have a friend able to do complex form grinding, it would probably be cheaper to buy a replacement shaft.
Earl S.
03-24-2004 20:20:52
 Re: Re: Re: Re: Splined shaft in reply to Davis In SC, 03-24-2004 20:03:01
The old John Deere is 1934 only worn used shafts available. Thanks Earl
