Tool Talk Discussion Forum
Belt sizing for my homemade generator
JOHN
03-22-2004 18:28:19
I need to know what size belt to buy.The distance between the center of both pulley's is 13 3/8inch's .One pulley is 8inch's and the other is 2.5inchs .It's a standard machine size width,look's like a autu belt from the car's 30years ago.Thank You for any help you can provide.
DaveCA
03-24-2004 17:26:12
 Re: Belt sizing for my homemade generator in reply to JOHN, 03-22-2004 18:28:19
I'm thinkin' ya might have to add a little, given the diameters are different. because the belts 2 runs have to reach the other pulleys diameter.
Harley
03-24-2004 14:58:55
go here to see if it helps Link
Vern-MI
03-24-2004 14:29:24
Wow a pulley ratio of 3.2 : 1! Either that motor or generator is going to be running REAL fast.
JOHN
03-26-2004 04:13:03
 Re: Re: Belt sizing for my homemade generator in reply to Vern-MI, 03-24-2004 14:29:24
The big pulley is on the gas engine,the engine does not run very fast but my motor(generator) is at the speed needed for the correct output.I tried it last night,now I need to mount the cap's and a receptacale box.
Gordon in IN
03-23-2004 20:56:04
Whatever length and width (cross section) "V" belt you need, try to get one of the "extra service" or "severe service" belts as used on riding lawn mowers and self propelled lawn mowers. They will pull more horsepower and last longer. Yes, and they cost more also, but you will not have to buy as many of them. Some of them are different color than standarsd "V" belts. I think I have seen some blue, some green, and some red in color. Also have seen some black with colored "patch" with the size and "exrta service" marking as well as some all black. You may wish to go as small (short) as you can to allow more room for adjustment. Good luck
willie j
03-23-2004 19:38:00
John
Quick & dirty way to get belt length, run a tape measure around the pulleys in place of belt, take reading & buy closest belt length.
HTH
Willie J
Mark
03-23-2004 13:07:12
Using your numbers, the exact length would be 43.8 inches. You can find the formula on page 260 of the Grainger catalog, or on their website.
T_Bone
03-22-2004 19:01:43
Hi John,
2.5 x 3.1416 /2= 3.927
8 x 3.1416 / 2= 12.567
13.375 x 2 = 26.75
Or 43.25 total. So a B430 (43") or a B440 should work if have adjustment.
T_Bone
JOHN
03-23-2004 04:26:57
 Re: Re: Belt sizing for my homemade generator in reply to T_Bone, 03-22-2004 19:01:43
HI T-Bone,I should have told you what size pulley,I am usingthe A or I think they are also called 4L type pulley.I have a 2.5 gas engine to drive a 2hp singal phase eletric motor .With 20uf cap's hooked on the output terminal's I get 135 under no load,ok for my tool's and lighting.135vac from 1 leg to frame of motor ,266vac between both lead's.DO you think a 44inch belt is still the size?
T_Bone
03-23-2004 05:15:57
 Re: Re: Re: Belt sizing for my homemade generator in reply to JOHN, 03-23-2004 04:26:57
Hi john,
Good thing you made me look as I was wrong on the "B" belt number, B40= 43"
Yes you are correct a "A" belt is a 4L430 or 43" If your measurement was taken from the center of slot adjustment then I would get a 4L430.
"A" v-belt = 1/2" at the top
"B" v-belt = 21/32" at the top and is a 5Lxxx series v-belt
3Lxxx series is 3/8" at the top
The math for length is correct as I rechecked my math. :)
About 10amps@115v max?
T_Bone
DL
03-23-2004 07:50:34
 Re: Re: Re: Re: Belt sizing for my homemade genera in reply to T_Bone, 03-23-2004 05:15:57
Hey T Bone... Wouldn't you use only 1/2 the circumference of each sheave??? The belt doesn't go all the way around each one when it's installed!!!
Correct formula should be... 1/2 circumference (pi x diameter) of sheave #1 plus 1/2 circumference of sheave #2 plus twice center to center distance...
Paul Janke
03-22-2004 20:07:36
He said a car from 30 years ago. That could be an "A" cross section belt.
T_Bone
03-22-2004 20:55:03
 Re: Re: Re: Belt sizing for my homemade generator in reply to Paul Janke, 03-22-2004 20:07:36
Hi Paul,
Thats true but I don't think he'll have enough grip with a single "A" belt and it's doubtful on a single "B" belt.
T_Bone
Kelvin
03-23-2004 18:26:11
 Re: Re: Re: Re: Belt sizing for my homemade genera in reply to T_Bone, 03-22-2004 20:55:03
I was told a 70a car alternator would pull at least 2hp at max current. Use a automotive v-belt. Better stay away from those fractional hp belts at the hardware store.
