Tool Talk Discussion Forum
abrasive cutoff saw performance
Tad
03-22-2004 07:56:04
I purchased an abrasive cutoff saw this weekend, thought it would be a step up from the sawzall and grinder routine. I was disappointed that it wouldn't handle 1-1/2" x 1" x 3/16" angle very well. I even gave up on trying to cut the flat of the angle and rotated pieces so I was always cutting on "edge". I was hoping to cut some 45deg miters, but the saw just wouldn't cut the flat. Sparks, noise, I kept the saw speed up, but if I would press down harder (frustration...) the saw would start throwing sparks off the brushes and let me know it wasn't happy.
I thought it should cut whatever thickness one could mount in the vise (within reason), just take your time - ? The specifications suggest that my use is reasonable. Are these saws only good for light metal, such as steel studs (tin) ? Is the problem a poor quality abrasive wheel? It is identified as a metal cutting wheel, came with the saw.
It is a Ryobi, 14", 3300rpm. It has a 30 day statisfaction guarantee, and I'm currently not statisfied - but am I asking too much of this type of tool?
Thanks,
Tad
HomerBinNC
03-26-2004 10:35:29
 Re: abrasive cutoff saw performance in reply to Tad, 03-22-2004 07:56:04
Tad,
I have that same Ryobi saw, it will cut 3X3X1/4 angle easy, I have cut 4" sch 40 but it is all that saw will do. I thank you have a bad saw or blade. The first cut-off saw I had came from a parking lot sale (off brand), it wouldn't cut 3/8" round rod.
Good Luck Homer
Farmered
03-25-2004 00:46:38
I never did like an abrasive wheel cutoff saw for anything I could cut with a band saw. The band saw is cleaner, quieter and more accurate than the abrasive wheel. The "chop saw" is great for wire braid hose or springs. Ed
teamjunkyard
03-23-2004 03:21:36
Both my brother andI have a milwaukee , they are gutless, next time I will buy better quality.
Bus Driver
03-23-2004 05:07:07
 Re: Re: abrasive cutoff saw performance in reply to teamjunkyard, 03-23-2004 03:21:36
The Milwaukee is the only one I have used, so I have no comparisons to make. teamjunkyard, What brand has your experience shown to be better? What brand will you purchase next time? I am surprised that your post did not just state that "brand X" is much better than the Milwaukee. We could benefit from that information.
teamjunkyard
03-23-2004 13:17:55
 Re: Re: Re: abrasive cutoff saw performance in reply to Bus Driver, 03-23-2004 05:07:07
well, I don't have any other brand to compare to but consider that this tool is meant to cut steel and should have more power. 2 inch square tubing is a challenge. there must be a company that makes a better one, more $ I'm sure.
Bus Driver
03-23-2004 15:52:35
 Re: Re: Re: Re: abrasive cutoff saw performance in reply to teamjunkyard, 03-23-2004 13:17:55
So when you buy another one, how will you know before purchase that it is better than the one you have?
Bernie in MA
03-22-2004 17:55:55
It sounds like your wheel got glazed over. It has to keep wearing so as to expose new cutting particles. I was told to lightly tap the edge of the wheel while it's spinning to make a small notch in it. It worked for me BUT I was using a reinforced wheel and was wearing a face shield plus glasses.
One other time, for some reason, the side of the wheel became tapered so the motor was stalling as the blade went deeper into the cut and became wedged. A new wheel cured that, after I called an electrician for nothing because I thought my 7 1/2 HP motor was going bad.
Bus Driver
03-22-2004 17:23:09
I have a Milwaukee, if I remember correctly it is made in Taiwan. But if it has a good electric power supply, it cuts well. I have cut 3" schedule 40 steel pipe with it and it does it quickly. Keep the blade (cutting disc) tight. Use heavy duty extension cord if cord is necessary.
Russ
03-22-2004 17:18:31
All of the Ryobi equipment I have used has been good quality, I think there is something wrong with your saw. Like someone said, narrow blades will cut the fastest, and I cut angle from the top down (A). My experience with chop saws is pull as hard as you can and maintain blade speed. Once the steel heats up ahead of the blade it cuts faster!
nwb
03-22-2004 16:29:15
Tad, sounds like you've got alot of good advice form knowledgeable people. I want to encourage you to try some more cuts with your saw. It sounds funny but there is kind of a knack for using a chop saw. I saw a neighbor use a chop saw years ago and decided to buy one. His saw cut so easily, I couldn't get mine to cut. Many of the same problems that you are experiencing. I kept trying and the saw started cutting. That was 14 years ago. I've cut 2"x2" steel bar in mine. (not recommended) Anyway you have 30 days to play with the saw. You've got nothing to loose, and experience to gain. Good luck.
Rob
03-22-2004 16:12:34
It sounds to me like you got this saw fro mone of those parking lot liquidation sales. They always sell the CRAP the stores reject or dont want to sell for other reasons. They normally break within the first month of purchase, the tools bought at liquidation sales. If that is where you got the saw, take it back and DEMAND a full refund for the unit.
Thanks - is RIDGID a trad
03-22-2004 15:38:21
Thanks for the feedback. Would a RIDGID metal cutoff saw be trading up from the Ryobi? I'm thinking of taking the air hose and blowing this saw off, box it up, carry an example of what it can't cut in my hand, and see if I can start over (back to the SawZall), or if I have to take a credit and trade up (if the RIDGID is trading up). Any thoughts on how Home Depot will react? Bit of an impulse purchase (tax refund burning a hole in the pocket...), but it sounds like an abrasive cut-off saw should "scratch my itch" if I get something decent and take my time.
Tad
ted
03-22-2004 20:23:53
 Re: Re: abrasive cutoff saw performance in reply to Thanks - is RIDGID a trad, 03-22-2004 15:38:21
Ryobi now makes RIGID. They still own emmerson (which used to make rigid - lifetime warrenty tools) but now emmerson no longer makes the power tools. Quality now?? Parts for older emmerson tools?? I think a lot of in store parts were clearanced out.
Charles (in GA)
03-22-2004 16:50:50
Tad, Being in the Atlanta area there are Home Depots all around here (their home office) and they don't complain in the least, or even ask, or care, why you want to return it. I've seen large compressors, I mean 7.5 horse two stage ones, out on sale after they were returned, Someone bought it, took it to a shop, painted something with it (it was COVERED in heavy, caked on overspray) and had the gall to return it. They planned on returning it when they bought it, Some people consider it free rental.
In your case, you are an honest customer, take it back with your sample and ask to return it, they will credit your card or mail you a check, depending on how you paid for it, and will smile about it.
Personally, cutting angle iron like you described, or virtually anything else (electrical conduit, PVC pipe, etc.) I use the daylights out of my cheap Chinese made horizontal bandsaw from Northern. Its the more expensive model, and I love it. Just plan on putting on a good name brand blade (starrett, etc) pretty soon, the Chinese blades won't hold up.
Charles
DL
03-23-2004 10:57:02
 Re: Re: Re: abrasive cutoff saw performance in reply to Charles (in GA), 03-22-2004 16:50:50
If you want to "trade up"... go with a name brand... Makita, Milwaukee, Bosch, maybe Porter Cable... most of the rest are junk
Terry G
03-22-2004 14:37:49
What is the thickness of your blade. I have found that a thinner blade cuts much better than one that is 1/8 thick. Most of the cheap ones are the thick ones.
Terry G
KX
03-22-2004 13:37:22
Tad,
I think you already know the problem, the brand you bought just isn't very heavy duty. That brand may be fine for light occasional use but not for anything even remotely heavy. The iron you describe would be nothing for a better quality more powerful saw. I have hawked my favorite here before but I won't again, I own 3 of the same kind and have abused them in ways that would have killed 100 inferior saws but they keep going. I have cut railroad rail before in one (it ate a whole blade and I had to rotate it after cutting 1/3, 1/3, 1/3). I would seriously consider taking the r--bi back and trading up. You won't be sorry, IMHO. Best of luck.
Ron in Nebr
03-22-2004 11:04:25
For what it's worth, I've found on our cutoff saw that sometimes if I try to cut to fast the darn thing almost quits cutting. Not sure of the real reason, but my theory is that the heat hardens the metal directly under the blade making it hard to cut. When it does this I can most always move to a different spot on the metal and by using very light pressure cut through the same peice of metal like a hot knife through butter... Another tidbit- when making straight cuts on angle iron I've had the best luck laying it flat with each edge on the saw table and the center of the "L" up in the air...kinda like an "A"(for lack of a better way to describe it). You start cutting at the center and it never has to cut a full-width flat peice. Wouldn't work for the miter cuts you're trying to do though.
DL
03-22-2004 09:27:42
Hey Tad, I think you got a bad saw... might exchange for a different one or for a better saw such as Makita... Ryobi tools are notorius for poor quality (man am I gonna hear about this!) We have an OLD B&D saw at work & use it to cut hardened steel pins (up to 3/4" dia), all types of tubing and various other structural steel. You can't "hog" through the thicker stuff, but a good saw with a full diameter blade should cut through just about anything you can fit under the vise... as an example, you should be able to cut through 2 x 2 x 1/4 angle in + - 30 seconds... WITHOUT burning up the motor!
Ron from IL
03-22-2004 08:52:03
Tad,
You're right--the saw likes thin better than thick, but if you're patient, it'll cut it. I made cantilevered deck supports a few years back out of 4" X 4" square tube (1/4" walls) and heavy (5/16") 4" X 4" angle. Here's what I found worked best for me:
1.) Keep a GOOD, full-diameter wheel in the machine. I stock up at the local farm store when they run a sale ($5/ea.). I keep about 10 or 12 on hand.
2.) Lock the trigger and put STEADY, not-too-firm pressure on the handle. It's easier and less fatiguing than trying to keep the trigger pressed all the time. You can soon develop a feel for just how much pressure is correct.
3.) Let it cool down once in a while if you use it for long stretches at a time.
A good vertical/horizontal band saw would probably work better in the long run, but your abrasive cut-off saw WILL do the job if you're careful and patient!
Good Luck!
Ron
