Tool Talk Discussion Forum
Morse taper drills
Kennyp
03-21-2004 15:25:13
Has any one ever turned down morse taper drills to a straight diamater? Friend just got a whole box full of old one. Closest he comes to using them is an old "blacksmith shop" post drill that uses 1/2 inch-flat on side one. How to soften the end without messing up the hardness of the cutting end.?
L arry E
03-21-2004 19:04:51
 Re: Morse taper drills in reply to Kennyp, 03-21-2004 15:25:13
The tang or shank end is not hard.A good carbide tool will cut it.
Slowpoke
03-21-2004 17:58:34
Do not turn them down. Just get an adapter. Or buy a set of Silver & Deming bits. Those old drill bits can cost $25-50 each to replace.
wdTom
03-21-2004 17:30:43
Hey you guys, I am looking for a set of #2 or #3 or mixed, morse taper shank, drill bits from about 1/2" to maybe 1 1/4" - 1 1/2" Are any of you think of maybe selling a few? I can sharpen them so that isn't a problem. I would want them to still be reasonably long and not totally beat to death. A little honest use would be OK though, understand they are used. Let me know if you are interested.
Davis In SC
03-21-2004 17:48:31
 Re: Re: Morse taper drills in reply to wdTom, 03-21-2004 17:30:43
Tom, I think I will hang on to the drills I have, but I have noticed that mixed lots of Morse Taper drills sell on Ebay for very little money. That would be a good place to find some.
Davis In SC
03-21-2004 15:42:17
The Morse Taper part of most drills is fairly soft, & will cut easily on a lathe using a carbide insert. It is hard to hold the drill in a 3-jaw chuck without damaging the drill or the lathe chuck. I have used a collet to hold the drill so I could turn the shank. I have about a hundred Morse taper drills, but hate to turn them down, because they cost a lot more than straight drills. I did buy a R-8 to #2 Morse adaptor, so they will work in the Bridgeport.
george md
03-21-2004 15:35:46
Kenny,
Don't ruin a good set of taper shank drills, get a sleeve with the MT inside and round
OD . Turn the round to the dia that you need
to fit the drill press, that way you only need
to turn one thing . The sleeves are only a few
dollars from MSC or any of the other machine
shop suppliers.
george
