Tool Talk Discussion Forum
Battery charger switch
JPatton
03-20-2004 23:38:40
I have a Wards charger that needs a new switch. The stem is broken so there is no way to turn the switch. It is a large portable unit with low, high, and boost. This switch has several connections on it. I know Wards is out of business. Does anyone know a company or website that may have what I need? Thanks
MarkB
03-21-2004 16:56:12
 Re: Battery charger switch in reply to JPatton, 03-20-2004 23:38:40
If it's a standard switch, you can probably find a match at Allied Electronics (see link) or even Radio Shack. You'll need to find a switch that has the same number of positions and poles (each layer of the switch is usually a pole). Of course the new switch might cost more than your charger is worth.
I think that just about all store-brand battery chargers are made by Schumacher. Although their site has nothing about parts, you might try giving them a call. Contact information is on their site, www.batterychargers.com
CRUSADER
03-21-2004 15:30:21
You might try getting the numbers off the switch and taking them to the Sears Repair Center. I have matched up a few this way. Seems that a lot of those switches were made with a plastic stem for the knob and liked to break off. It's possible that Sears and Montgomery Ward Battery Chargers used the same vendors and that switch will match up.
Hope this helps some.
Jim
Mac
03-21-2004 07:40:14
I think that is called a rotary swx. Might try grainger or mcmaster carr.
JPatton
03-21-2004 07:45:13
 Re: Re: Battery charger switch in reply to Mac, 03-21-2004 07:40:14
MAC Thanks. Yes it is a rotory switch. I will look in my Grainger book. Thanks J
