Tool Talk Discussion Forum
Building a Vertical Metal Cutting Band Saw
Dave
03-17-2004 07:55:03
Does anyone know of a site to buy parts to build a Band saw ?? was thinking about building a Vertical metal cutting band saw , I think the wheels would be the first thing to buy?? maybe 14- 18 inch maybe ?? thanks Dave , or maybe you know of one for sale??
I am in Western Pa
wdTom
03-17-2004 17:42:44
 Re: Building a Vertical Metal Cutting Band Saw in reply to Dave, 03-17-2004 07:55:03
I have heard of using flywheels from car engines for the wheels of a bandsaw. You would need to make the frame, blade holding guides, top wheel tracking and tension adjustments, and some drive system, either gear box of some sort or double jackshaft reduction. For the work involved you could probably buy one of the import wood saws and reduce the speed. Making one would be a good project though and if you did a good job it would bring you a lot of satsfaction and you would have a way better saw then the imports.
Dave H (MI)
03-17-2004 10:24:32
Check your local auctions for a few months. I see a fair number going cheap.
ray
03-17-2004 10:50:29
 Re: Re: Building a Vertical Metal Cutting Band Saw in reply to Dave H (MI), 03-17-2004 10:24:32
You can order the bandwheels (from Jet) used on the Jet bandsaws. There in the $100 range each( Diameter = 19"). I think the wheels will take up to a 1.5" width blade.
Jet9N
03-17-2004 09:43:23
I built one some years ago. I got the "V" pulleys
from an old IHC forage harvestor. Right price,
free from a neighbor. They are about 19 and 22 inches in diameter, so had to offset the centers
to get the business side of the blade verticle.
Glued the "V" belt into the groove. Used a 4 speed
truck tranny with "granny" gear for drive and use
1st and 4th. Gives me about 125 and 800 fpm. Works
fine for both wood and metal.
HTH
Jet
Slowpoke
03-18-2004 01:37:44
 Re: Re: Building a Vertical Metal Cutting Band Saw in reply to Jet9N, 03-17-2004 09:43:23
You have a great idea in using a tranny for the saw. I've tried to figure out the ratio to convert a wood bandsaw to cut steel, but it runs into too many big and small pulleys and jack shafts. What HP electric motor are you using to run the transmission and saw? It seems like it would take 3 or 4 at least. I have an old garden tractor tranny that might handle the power. It would take less power and less room than one from a full size truck.
Jet9N
03-18-2004 08:21:24
 Re: Re: Re: Building a Vertical Metal Cutting Band in reply to Slowpoke, 03-18-2004 01:37:44
I only have a 1 HP motor on it. Works fine. The motor drives a worm gear which is coupled to the
tranny. Then there is a roller chain drive to
the shaft with the big blade pulley on it. I run
motor oil in the tranny which reduces drag some.
Jet
Rick
03-17-2004 08:52:51
You should be able to get a one, in good shape from all the companies going down the drain in the USA.
