Ventilation fan for garage
Ken
09-09-2000 12:38:25
I want to put in a ventilation fan for my garage and wonder how big of a fan to put in with-out taking all the heat out in the winter months. The garage is 24x40 ft. with 10 foot ceiling, 6" wall insulation, 12" in ceiling.
Scott Green
09-10-2000 06:59:52
 Re: Ventilation fan for garage in reply to Ken, 09-09-2000 12:38:25
Ken , I have a shop very close to what you have.I have 3 turbine vents on the roof. Two of them are for the attic , and one comes down into the garage for exausting fumes from engines , welding , etc.. It does work , but not as good as I hoped it would. I'm going to put a fan on my ceiling , at the bottom of the shaft going to the turbine vent. I think that will work out really good. The turbine vent keeps the weather out , yet keeps the air circulating. For heavy fumes , the fan would move the air a lot quicker. The air shaft is in the center of my shop. I heat with wood/coal. I planned on heating it with gas or oil , but I guess I'll rule that out due to prices. One other thing I need to do: The shaft between the turbine vent and the ceiling is metal. I need to insulate the exterior of the shaft in the attic. The difference in the attic air temperature , and the air temperature traveling up through the shaft , causes condensation , which drips water out the bottom of the shaft. Insulation will take care of that. I live in New York State , where the weather is always changing(four seasons). Mark-NC is very acurate on what he had to say. I'm telling you my own situation. You have to concider all the facts Mark had mentioned. Is this shop your own private do everything in it shop , or is this shop dedicated for one special purpose in mind. My shop is a do everthing shop. The factory I had worked in used turbine vents , along with power vents. They were spaced along the ridge of the roof. They do a lot of welding. The fumes seam to exaust ok.
Mark-NC
09-09-2000 21:01:51
Ken,
Need a little more info. What are you doing in the garage that needs ventilation? Running an engine, welding, or do you just want some outside air in general?
Also, what is the source of heat for your garage and the expected outdoor temperature?
General tips for exhaust: Locate the fan near the source of pollution. Also you need a positive means of making up the air that you are exhausting out. If you don't, the outside air will be coming in every crack and opening in the garage. I would locate the makeup source near the source of heat, so the air can be somewhat preheated before circulating into the garage.
Another important tip: If you have any gas heating appliances in the garage (water heater, furnace), you don't want to put the garage under negative pressure. The draft hoods and flues won't work properly and may even allow combustion gases (including carbon monoxide) to collect in the building.
Fill in the details and I'll let you know.
Ken
09-10-2000 09:22:00
 Re: Re: Ventilation fan for garage in reply to Mark-NC, 09-09-2000 21:01:51
I do run engines and do some welding and painting in the garage for my personal use. The wife says I'm going to kill my-self in there. I have a gas furnace and the Wisconsin winters can get from -0 to -20 to -35 degress below zero. I do have 2 windows that I could crack open for fresh air intake.
Mark-NC
09-10-2000 19:36:09
 Re: Re: Re: Ventilation fan for garage in reply to Ken , 09-10-2000 09:22:00
Ken,
For general purpose ventilation, you can probably get by with 2-3 air changes per hour without freezing yourself. In your case this would amount to between 320 and 480 CFM. This won't clear your shop out very fast, but for intermittent welding or running an engine you should be okay.
You need to check your heat source to see if it can keep up. Let's say it's -35 deg. outside and you heat the shop to 65 deg. It will take 108 BTUs for each CFM of air that comes into the shop. For a fan that exhausts 320 CFM, it would take 34,560 BTUs to heat the air plus heat that is lost through the walls. If your heat source cannot put at least this much heat out, then expect the temperature in the shop to drop as the fan runs.
Also as I said before, since you have a furnace, make sure you open the window when the fan runs to allow the exhaust flue to operate properly. (Unless you have a furnace with a "sealed combustion chamber", which will have two pipes to the outside. One for combustion gases and one for makeup.) If you want to get fancy, you can mount a switch on the window to keep the fan from running unless it is open.
Hope this helps.
