Tool Talk Discussion Forum
air compressor tank
jeremy
03-15-2004 18:09:45
I was given a pumpand motor and need to know where I can get a tank. Thisa large unit that was in factory.
Jeremy
Mike in IL
03-18-2004 21:27:16
 Re: air compressor tank in reply to jeremy, 03-15-2004 18:09:45
One think to caution you on, if you plan on using a tank made for water applications. These tanks are usually made thinner than those for Air. What this means is that even though they may handle 200 PSI they will not withstand repeated pounding from a air compressor pump.
Unlike a water pump or munincipal supply were the pressure builds at a smooth rate, an Air compressor literally pounds the air into the tank. This is done be compressing small amounts of air into the tank at a time. The suggestion to get an ASME certified tank is an excellent one. It will cost more but it will outlast anything else.
Slowpoke
03-16-2004 00:58:55
Sounds like you need a horizontal tank.
Grainger has ASME horizontal tanks. 60 gal, $425, 80 gal, $485. I just bought at a yard sale, a used Speedair 5hp, ASME 60 gal verticle tank, 9.5 cu ft @ 135psi for $200. It was made in 2001 and is still listed in the catalog for $479.
Jeremy
03-16-2004 19:31:33
 Re: Re: air compressor tank in reply to Slowpoke, 03-16-2004 00:58:55
Thanks, I got a new catalog at the office still in the box.
Jeremy
JT
03-15-2004 21:24:34
Thought I got the link to work.
Here it is
www.surpluscenter.com
JT
JT
03-15-2004 21:23:04
I would be real careful about using any tank originally built for a water system. If it is tested there would be a ASME tag on it somewhere. In addition to this you never know how much rust there is. Case 110 hp steamer's were tested but they get thin to!!
Try this outfit.
HTH
JT
old
03-15-2004 20:20:09
This may sound crazy but a used gas water heater tank works well for a preassure tank, they are tested to 300 psi so if its good it will hold 120-130 psi with no trouble
Charles (in GA)
03-15-2004 19:10:57
Before you go chasing around looking for a tank, make sure you can make it all work. Is the motor single phase or three phase, and what voltage?
If it is a large "factory" compressor, it most likely is three phase, and if it is more than 7 1/2 horse is is 99% chance it is 3ph. Do you have 3 ph to run it? The other consideration is even if it is single ph, do you have the current available to run it?
Just something to consider.
Charles
John *.?-!.* cub owner
03-15-2004 18:27:05
Try www.northerntool.com or www.harborfreight.com
