MF 65 diesel fuel leaks
Cliff in Al
09-09-2000 10:27:03
I have a leaking fuel filter head where the fuel line attaches. It looks like the threads on the head are stripped out. The fitting will not tighen up. It gets to a point and then will not go any tighter even though the nut continues to turn. Is there a better way than replacing the fuel filter head? I also have a leak at the fuel shut-off valve coming out of the fuel tank. It is leaking at the wing nut. Any suggestions on this other than replacing?
Thanks for the help- trying to save a buck.
bbott
09-10-2000 14:50:15
 Re: MF 65 diesel fuel leaks in reply to Cliff in Al, 09-09-2000 10:27:03
Quick/dirty/cheap and since it's already shot....
Epoxy it.
Of course, then if you ever go to fix it right you'll have to replace the fuel line too.
bb
