Piston ring needed Help
smith
09-08-2000 03:39:34
Does anyone know a place on the Web that sales small piston rings?Need a 2 inch ring.Width and height of ring is 2MM.Goes on old pulley type air compressor.
Roger Prosper
09-09-2000 10:35:39
 Re: piston ring needed Help in reply to smith, 09-08-2000 03:39:34
Get a Hastings piston ring catalog. Any good speed shop or engine rebuild shop should have them for sale. You can cross match virtually anything with a bit of measuring and patience. I rebuilt an obsolete Ceccato compressor that way. Some high pressure rings for small two-stage compressors are very hard to cross reference though. What type of compressor is it?
Tim W
09-09-2000 02:53:57
Try Dave Reed at [email protected] .or 410-398-7340.
I have benn satisfied with my dealings with him.
Corky
09-08-2000 03:44:11
You might want to try a lawnmower repair shop.They would have an assortment of small rings.
David Fisher
09-13-2000 19:47:35
 Re: Re: piston ring needed Help in reply to Corky, 09-08-2000 03:44:11
Try calling Paul Weaver's Garage (piston Rings 1" to 10") 680 Sylvan Way Bremerton WA 98310 PH.(360) 373-7870
don
09-20-2000 11:03:24
 Re: Re: Re: piston ring needed Help in reply to David Fisher, 09-13-2000 19:47:35
go to a napa machineshop and you can find rings by bore and width in the perfect circle catalog..i ran such a shop for 25 years....don
