Tool Talk Discussion Forum
Suggestions for grading a long driveway
KEG
03-12-2004 20:10:48
I am building a +2000' driveway in soft, sandy soils. It is rough graded but now I need to finish grade it smooth and level. I am having difficulty getting a level, even surface using my grader blade behind my tractor. Is there a technique to using a grader blade to accomplish this? Would guide wheels welded to the back of the grader blade help to keep it from digging in too much? I could work with a Bobcat but that seems more time consuming and tedious. Don't have access to a motor grader or bulldozer.
Thanks for any thoughts.
KEG
wdTom
03-14-2004 17:28:23
 Re: Suggestions for grading a long driveway in reply to KEG, 03-12-2004 20:10:48
The other Tom mentioned it some but I will add my $.02 worth. You need to crown the sruface and have ditches at the sides. The crown will make sure the water gets off in the shortest distance. You don't want the water to build up anymore than necessary as it carries away gravel as it runs. If you get a puddle each tire that runs through the puddle will splash water AND GRAVEL out and the hole will get bigger, and bigger, and bigger, etc. A good crown prevents this. On hills you want even more crown so the water doesn't tend to run down the hill and take your gravel and make gullies. Now to get rid of the water you need ditches at each side of the road. As for what works best for grading, well, a road grader of course, but it doesn't have to be a real one, just a center mounted blade will do wonders. Each bump or dip the wheels hit will affect the blade less if it is in the center and the back wheels get the advantage of running over the graded surface. Although it is too light for the job you have, we have a Farmall Cub with a blade that can be center mounted and it works great for small jobs, just like a roadgrader, but in mini size. Most blades made for grading have an adjustment for raising or lowering the sides so you can crown a road.
Dr.EVIL
03-16-2004 10:12:21
 Re: Re: Suggestions for grading a long driveway in reply to wdTom, 03-14-2004 17:28:23
Don't sell the FARMALL CUB short. I made a belly mounted grader blade to bolt onto My 10 HP Cub Cadet in place of the mower deck. It's 6" high and 40" wide and pivots about 10, 20, and 30 deg. both ways. It's made from a road grader blade cutting edge. Works great for leveling crushed rock drives in the spring after the frost leaves the ground or after rains. I used to have a 1/4 mile crushed rock drive full of potholes but after I lived on the place a month they were ALL gone. Place got a lot of heavy truck traffic too, loaded tandem grain trucks leaving all the time. I've also used the blade to landscape swimming pools, prepare grade for concrete, scrape ice & snow from the driveway. Bolts on with four 1/2" bolts.
wdTom
03-18-2004 16:35:11
 Re: Re: Re: Suggestions for grading a long drivewa in reply to Dr.EVIL, 03-16-2004 10:12:21
I am not really selling the Cub short I don't think. Just saying they are not too heavy and not too powerful. They are good for a small driveway, we keep 3 such drives graded with a Cub. And they are excellent for spreading grading new materials. But for scraping and grading a hardpacked road or drive I still say they are a little light. Hardpacked gravel or dirt mix can be like cement sometimes.
Don L C
03-13-2004 17:06:22
Pull the gravel in from both sides...set the blade straight but not to deep .... pull a drag to level it up.....a section of chainlink fence with a 2x6 across the front.....
Dave H (MI)
03-14-2004 06:41:16
 Re: Re: Suggestions for grading a long driveway in reply to Don L C, 03-13-2004 17:06:22
I'm with Don. I do a LOT of grading with a blade on our road. Angle your blade so that the gravel goes to center. Go up one side and down the other.
Then straighten the blade, lower to desired height and straddle the center pile with tractor.
Finish with a drag of some sort and it should be done. On final pass with blade try NOT to have front wheels go down into any holes if possible.
Occasional use of a rake may be in order. Not too hard to do.
John K
03-13-2004 07:56:48
I use a 14 x6 10' I beam that is dragged at about 15 degree agle off perpendicular to the direction of the tractor direction. With that setup, it takes the rigdes off and fills the hollows. It sure removes wave effect on the lane way. I even use it after I put down new gravel, with the angle adjusted to be more than 15 degrees, it tends to move the gravel to the side that is furture back, great for spreading. I just bought a 30 inch cyclinder that I will be putting on one side to the beam. At mid point the beam will be perpendicular to the tractor, by either retracting or by extending the ram I will be able to change direction of which way I want spead or fill areas. By the way my lane way is 1000 feet long and have about 150' diameter yard at the top of a steep hill. I get a lot of truck hop on the steep part causing the road to become wavey. Each trip up the hill by vehical makes the road worse. With the use of the beam behind the tractor I am slowly getting the road firmer but only need one pass to smooth it out. Sorry for the long reply.
ted
03-13-2004 06:57:11
Find you a piece of I beam, hook a chain on to each end and drag. if it's not heavy enough you may have to add some weight. In a pinch have somebody stand on it. This will smooth it down decent. You may have some luck pushing in reverse with your blade backwards (moldboard towards the tractor). This prevents digging and just pushes the gravel around.
Carol Martin
03-13-2004 06:42:22
Hi Keg;
I think you have the right Idea with the Guide wheels on your blade.. I made a set for my blade and they work great. I get a lot of washout on my drive when we have HEAVY downpours. I have crushed stone on the drive and with the guide wheels I can get it as smooth as a grader.(not as fast as they can) but with a little practice it is not too hard. Attached is picture of my setup. If you make one be sure you set the wheels in far enough so that they will follow behind the blade when you have it set at an angle. I goofed the first time!
You can either use the top link to adjust (I do) or you can make the wheel height adjustable. You can crown the drive by adjusting the Leveler on the 3Pt
Carol
Ron 1456
03-13-2004 06:38:30
If you wish to do it all yourself try using a drag scraper. They come in all sizes and prices and someone nearby probably has one you can use or rent. These scrapers work better than a mounted box scraper because they are pull type and are not affected by humps or dips that the front wheels go through. The one I use is a "Big Dog" feedlot model that is 12ft and weighs 3000lbs but you can find much smaller ones (or much much larger ones) which may better fit your needs. We use it for dirt work, fine grading, spreading gravel or rock, snow removal, and anything else we can think of.
John
03-13-2004 06:15:20
Bonnell Ind. makes a road maintainer for gravel roads that you can pull behind a truck or tractor. They are located in Dixon Ill. and have dealers all over. If you are going to leave it gravel this may be worth lookin into. They have a web site. try Bonnell.com or e-mail me and I can get you more info. John
Errin OH
03-13-2004 05:55:50
I doubt you'll get the results you want with a straight bale. Their good for fillin in and removin high spots but tend to leave ripples like a slow ocean roll. Box blades are better, they keep material in them and it can't roll off the edges like a straight blade. As long as it does fill up and spill out. The main issue I have is the setup. A 3pt blade is at the mercy of the front wheels. As it raises up the blade digs deeper, as it falls in to a hole the blade lifts up. Thus the rolling wave results. A drag would most likely work for finish but plan on a lot of trips up and down the drive. I prefer about 15' of 6' chain link fence, with some weight. Say 25 house bricks space out some what evenly on it. I have had some sucess pushing the blade as I back up. Leave the blade facein forward so it doesn't dig in, and push the material. As it rolls under it tends to leave it a little flater and the tractor front end is ridin on the finish and not the rough cut. BTW a bob cat works great for this. Set the bucket to a slight down ange (say 20deg) and then lift the front set of wheels off the ground (isn't down pressure great) and run backwards. By riden on three points (two back wheels and bucket) you don't have the rollin problem. I leveled bout 60 ton of dirt that way and was very pleased with the results.
Tom
03-13-2004 05:54:24
Keg, your best bet is to bite the bullet and hire a roadgrader to come in. He can put the proper crown in the road, and the proper amount of bar ditches on either side. This will provide the proper drainage and result in a road that will give your years of trouble free service. After he can spread your gravel for you. Should be 4-6 inches thick after compacting. The final shap of the driveway should be crowned up in the center slightly - - not flat.
RWK in WI
03-13-2004 05:39:40
I have found that getting rough spots and washboards out of sand gravel driveway / roads can be fustrating but these ideas have helped.
Work against the way traffic normall flows on the road - stay to the left
Never make two passes in a direction with the blade angled the same way - change the angles
Make finish passes in the center with the blade turned backwards.
Sometimes going at moderate speed is better than going too slow. It takes time but you will get better with practice and you get good tractor time.
KURT (mi)
03-13-2004 05:20:44
I have a 900' long driveway and two years ago my one neighbor had a 25HP new holland tractor with a rear 3pt and a york rake. (he doesnt have it anymore) That york rake did a good job of digging in about 4" and grading the gravel and covering over the dips in the drive due to construction, heavy dump trucks and concrete trucks. You could probalby rent a rear 3pt york rake from a rental yard for the day.
jf
03-13-2004 02:06:56
if their is no gravel down may I make a suggestion that you will never regret. GEOTEXTILE FABRIC-we built a 1300 foot drive in clay soil with 10-20% slope in places. This stuff is fantastic-it will decrease you longterm maintiance cost by a huge amount. It is a nylon based material that you roll out-built our drive in 2001 and only have put 20 ton of gravel and that was because I was cheap in 2001 and did not put down the recomended 4-6 inches that I needed anyway. It in essence helps the gravel to float on top of the dirt-keeps them seperate. My neighbor who has been in the gravel hauling business 30 years was skeptical in 2001-now a firm believer. That being said make sure your base is free of topsoil and that the it is down to a strong sturdy foundation. Topsoils have organic matter and through their decomposition they lead to potholes among other problems. Drainage is another huge issue. Keep that water away from drive especially the part you drive on. The drive (as far as application of gravel)was the last thing we did believe it or not I made all the 40 ton concrete trucks drive over it so as too pack it as hard as I could, along with other trucks. One guy said you ever heard of gravel-my response yes and I will put it down when I get ready. Preperation like so many other things in life is the key.
RZ(Wa)
03-13-2004 08:53:24
 Re: Re: Suggestions for grading a long driveway in reply to jf, 03-13-2004 02:06:56
Yep! a geotextile is the way to go. Not too expensive in the short run abd well worth it for the long haul. I salvaged a bunch of it from a construction site shortly before building my house. I too mentioned it to a couple of local excavation contractors, they hadn't heard of the stuff and weren't too sure of it doing much good. Anyway, after them saying they would not warrant the driveway, etc. I had them prep the road (remove the sod)then I laid down the fabric. and had the gravel laid and spread. It's been 8 years now and I haven't had to repair potholes, smooth/level, or place any additional rock or gravel (unlike a few of the neighbors). It just keeps looking better the more it is used. Even used it at the gate entrances to the fields after removing the sod and with a little gravel added. Sure keeps the ruts in check.
Grant
03-12-2004 23:11:42
Doing it with the blade is going to be frustrating, whether its facing front or rear. Pending how good you are with the blade on the back, the aforementioned methods will work, but will take TIME. Usually when I grade driveways with the blade, i take an average depth of my grade and run the tractor back and forth until the highs have eliminated the lows. It can be done with the tractor but the skids are much faster, provided you have some experience and know how with them. If you have a friend that will loan you one, use that. It'll be far easier and much less time consuming. However, if you have to rent one and put up around $100 for the day, the blade might be better financially. If you do get the skid loader, remember that they react far differently than tractors do to bumps, hills, and mud. They are the most handy machines on the job, and also the most dangerous when not run correctly. Everyones put up good advice, so, hope this helps and good luck.
T_Bone
03-12-2004 21:41:16
Hi Keg,
What I built for a yard drag/level is two 10ft rail irons, spaced apart 10ft with 1-1/4" pipe on either side, then "X" braced with flatbar (keeps it square). I used a scrap piece of 1/2" wire rope to pull it with. I use another piece of 120# rail chained on top for weight towards the front of the drag.
As you pull this it digs in about 4" or so in front and places the dirt in the low spots if needed, if not then the dirt rolls over the front rail and is spread with the rear rail. The more weight thats in front, the deeper it digs. The flat of the rail iron keeps it from going too deep.
I cant the drag about 10� as this doesn't leave a high dirt berm on the finished edge. If I want to clear sage brush or small bush then I cant the drag about 30� and hit the bush/sage with 1/3 the drag width as this pulls out roots and all. I can clear one acre in about 2hrs with someone removing the sage that gets hung up in the drag. Then its just dragging over 4 times for a finished level grade.
I have also used this drag on 3/4 gravel roadways and it works well with out taking the gravel off but covers the road rutts.
T_Bone
Wayne
03-12-2004 21:01:43
I agree with Charles, you can turn the blade around and maybe even weight it down some and do it that way. It would be basically the same as back dragging it with a dozer blade or with the Bobcat bucket. Personally though if it's a decent size Bobcat I'd just use it. With the bucket on the ground and picking up the front of the machine just a little bit you can back drag the fool out of the drive. This way you have the weight there to move the dirt like you want to. Also, to me, it'a alot easier to be dragging the dirt and simply roll the bucket back up a little when you want to drop, smooth, and level the load it's pulling in a low spot than it is to try to raise a pull blade up. Doing it like this, for me, always seems to leave a bump that had to be worked back down flat. I did Dad's 250" drive, with a LX665 New Holland, after the power company dug it up putting in a new service line, in about an hour and a half one evening. Using a skid steer is definately fast when you get used to doing it. Just my .02, have fun.
Charles (in GA)
03-12-2004 20:31:30
Turn the blade backwards to get a decent finish. It cannot dig in, but will drag dirt/rock and some will drop off and fill low spots as you go. I do this with a roll over box scrap and it works well.
Charles
mj
03-13-2004 08:28:32
 Re: Re: Suggestions for grading a long driveway in reply to Charles (in GA), 03-12-2004 20:31:30
Like Charles said. If you angle the blade a bit and work from one side clear across and then repeat from the second side the blade will smooth out the ridges and ripples better. Straighten blade to finish with a light touch.
