Tool Talk Discussion Forum
Lincoln SA-200 welder - oil filter
Doug Stockman
03-12-2004 18:16:58
Greetings:
I recently purchased a Lincoln SA-200 gas powered DC stick welder. It has an F-163 gas engine. The oil filter on the machine right now is a Wix 51110. A replacement oil filter costs around $75. Is a less costly oil filter able to be used in this machine? If so, what type? Thanks for any help you can offer.
Doug Stockman
Penfield, NY
Bob
03-12-2004 20:46:11
 Re: Lincoln SA-200 welder - oil filter in reply to Doug Stockman, 03-12-2004 18:16:58
The WIX filters Master Catalog lists a WIX #51010 filter for the 200 amp model, and under Continental Engine F-163 they list the WIX #51010. The 51010 is listed as a cartridge type lube filter with a metal cannister.
The WIX # 51110 is listed as a spin-on lube filter, with the most common application being Wisconsin engines.
Is yours a spin-on, or a cannister filter, and is your engine in fact a Continental F-163?
doug stockman
03-13-2004 02:57:47
 Re: Re: Lincoln SA-200 welder - oil filter in reply to Bob, 03-12-2004 20:46:11
Thanks for everyone who replied!
It is a spin-on oil filter and it is a Wix 51110. The name plate on this very clean engine says it is a Continental F-163. Given other people owned this welder, it is possible they put the wrong filter on, but it is working well to the best of my knowledge. I will attempt to stick with it or its equivalent unless one of you fine people know what type of spin-on filter is supposed to go on this engine.
I will try a different auto parts store in town and see if I can get a filter for a more reasonable price. The Wix web site listed one store a couple miles from me. Maybe they have the Wix or Purolator listed below.
Best wishes and thanks.
Doug Stockman
Penfield, NY
Bob
03-13-2004 07:07:27
 Re: Re: Re: Lincoln SA-200 welder - oil filter in reply to doug stockman, 03-13-2004 02:57:47
I checked with my local WIX dealer this morning. $5.95 for the 51110! Someone was sure B.S.'ing you on the $75.00!
doug stockman
03-15-2004 03:19:36
 Re: Re: Re: Re: Lincoln SA-200 welder - oil filter in reply to Bob, 03-13-2004 07:07:27
I went to a different autopart store. They are special ordering the Wix 51110 for me. It will be around $6. Much better!
Thanks for all the help.
Doug Stockman
Penfield, NY
Charles
03-12-2004 20:39:13
I just changed mine on my machine.NAPA has it right in stock.Spin on and the # I think is 1050 wasn't much at all.
Charles (in GA)
03-12-2004 20:27:24
The links given in the text will have to be carefully copied (left click, drag to highlight, right click opens menu, then "copy") and then pasted in the address bar (left click in the address bar, backspace to clear, right click to menu and them "paste")
Well, someone is pulling your leg, according to the Purolator web site
www.pureoil.com
a Wix 51110 crosses over to a Purolator L30019 which according to the Advance Auto Parts web site costs $4.98.
Follow the link below and when you get the page, click on the p/n 51110 link and you will get the specs on this filter.
Link
