Tool Talk Discussion Forum
Three phase power
Slowpoke
03-12-2004 10:52:19
If a machine has a 240v 3 phase motor, can the motor be replaced with a 240v single phase of the same size? Is there a 120v component in 3~ that is used to operate controls and indicator lamps? In other words, if I bought a 3~ steam cleaner (or other machine) can it be converted to single ~ by replacing motors only?? There's lots of 3~ motor driven equipment that sells for little or nothing because most home shops don't have 3~ power.
RusselAZ
03-12-2004 19:32:42
 Re: Three phase power in reply to Slowpoke, 03-12-2004 10:52:19
I have 3 - 3 phase convertors, solid state from the Cedarberg company. Not very expensive, under 200 dollars each for up to 7 HP. they have other sizes. A few years ago the one on the air compressor quit and they fixed it for $75.00. still cheap. ANd you can use more than one motor on each, but not at the same time. Just wire the starters for each motor from the 3 phase side.
You don't have to be afraid of three phase motors ever again. Provided your power pole has enough power. Keep it a secret though. That way you can keep going to swap meets and buying those "junk" 3 phase motors for pennies!! And, and - and people will give you WHOLE pieces of equipment because it has a 3 phase on it.
Gk
03-13-2004 20:23:48
 Re: Re: Three phase power in reply to RusselAZ, 03-12-2004 19:32:42
Do you have the address for the Cedarburg Co?
RusselAZ
03-13-2004 22:59:43
 Re: Re: Re: Three phase power in reply to Gk, 03-13-2004 20:23:48
I'm going to try something new,,this URL link thing. but, just in case, here is the web site.
Link
GK
03-14-2004 12:06:45
 Re: Re: Re: Re: Three phase power in reply to RusselAZ, 03-13-2004 22:59:43
Thank you.
Roger
03-12-2004 14:10:07
!!DO NOT ATTEMPT ANY WIRING IF YOU ARE NOT SURE OF WHAT YOU ARE DOING!!
Electrical codes exist for a reason. So do electricians. Make judicious use of both!
Having said that:
Usually you can convert the motor to single phase without a problem, except the amp draw will be (slightly) higher, if the machine was orignally running on 240V. Most controls, on air compressors anyway, are 120V. The 120v is converted down from full line voltage through a transformer off of one phase. For example, I have a 20hp three phase compressor with a magnetic starter, running off of 575V. In most cases, I do not want 575V to operate the controls, just 120V (for solenoids, pressure switches, motor starter coils etc). In this case, I take 575V off of one phase (two mains) off the top of the starter, and bring it to a step down transformer that converts it to 120v to operate the controls.
Look for a control transformer in the starter box of the machine you are looking at. If it is a 240V, 3ph machine, and the transformer takes power from one phase (two mains), and brings it to a transformer, you likely already have your 120V source to run your controls. The transformer should have a diagram on it to show what the primary and secondary voltages are, and how to wire it for your application. Most 240V, 3ph motors will also run at 460V, so double check to see what the starter and motor are actually wired to run at. Many control transformers will accept either 575V or 460V on the primary as well. I would not recommend bringing in 120V from an outside source to run the controls, as it usually illegal, and is an electrocution hazard for anyone working on the system who doesn't realise there are two sources going into the box. I have been bitten by that a couple of times.
You can use a three phase starter for single phase by using just two contacts on the starter. The starter coil itself will not require 3 phase. It is a simple magnetic coil that pulls the contacts shut.
Long story short: converting to single phase from 3 phase is not a difficult process. The motor is almost always the only component that requires 3 phase,and control voltage is tranformed from the mains. Usual worst case scenario, you will need to swap out the motor starter coil and install a different transformer for the controls, as well as installing the single phase motor, of course. I do not know if this is the case for a pressure washer, the heating element might require 3 ph. I can't see this being a big problem, as an element will heat as long as there is power going through it, but I cannot say for sure. (CONSULT AN ELECTRICIAN!)
Keep in mind that single phase power is less efficient than three phase, so your power draw will be a bit higher on single phase.
Remember, a good single phase motor can be a pricey propostion. Get a price on a motor beforehand, so you do not end up with a project that makes no economic sense.
This is based on my own experience with compressors and controls. I am sure electricians on the board can elaborate further.
I am not an electrician. I don't even play one on T.V. This information is simply a guide to help you estimate the amount of work required to convert a 3phase machine to operate on single phase. It is not a intended to be a template for wiring up any starter or control system.
Chris-se-ILL
03-12-2004 13:57:22
There are guys on this forum that can tell you all about the differences. I will relate my limited knowledge about 240-3phase ~vs~ 220-single phase.
When I wire up a 3 phase motor:
it uses two 120V wires that are on different phases {the cycles are opposite each other}, plus there is a 180V "wild" line. 3 wires total with no ground. If you reverse the 2 120V wires the motor runs backwards.
When I wire a single phase motor:
it uses two 120V wires and a ground wire. No wild line!
The 3 phase motors are more effecient, and usually cheaper (around this area). When Dad designed and set up our grain handling operation he had the local power company put in 3 phase power to the farm. Most of the farms around here are single phase setups. We use both styles of motors around the farm, but we use the 3 phase whenever possible. The motors are smaller and more effecient.
Different wiring, different controls.
Roger
03-14-2004 14:27:06
 Re: Re: Three phase power in reply to Chris-se-ILL, 03-12-2004 13:57:22
Interesting, I have never heard of, or seen a "wild line" ever before. Whenever I measured power, it was 100-120V per wire to ground (200-240V single and 3 phase) or 220-240V per wire to ground (440-480V 3 phase). Measuring both wires in a phase gave me 200-240V per phase, or 440-480v per phase. The only weirdness seemed to happen when I measured 575V, when one wire to ground would give me a reading of 370-380V for some reason, but 575V per phase.
Is it true that the US does not use 575V? I have been told that 460 is the highest "common" industrial voltage level in industry there (barring 2000V, 4160V etc).
I have never heard of 2phase power. Two lines coming in at 110-120V apiece was always 220-240v single phase in my experience.
Two wires that were more than 10% apart in voltage were also considered to be out of tolerance. I had one machine with 220V on 1 phase and 190V on the other 2. It was constantly blowing motors.
joe
03-20-2004 08:20:23
 Re: Re: Re: Three phase power in reply to Roger, 03-14-2004 14:27:06
the old wild line..or..."wild leg" as we call it in the trade i believe applys to Delta wired systems...beacuse of the tap on a delta wired transformer i believe it gives you higher voltage to ground on that wild leg..we were required to mark that leg with orange tape...i also think this usually apply to DC voltage in most cases...its been years since i worked in such a system....
Farmered
03-13-2004 03:19:28
If you have a line which is of a higher voltage than the other two (wild) you likely have a delta Y system. These are cheaper for the power company to install in rural areas where long distances are involved since they use only two hots and a ground overhead. I once put in a 20 HP 3PH submersible pump on a delta Y system. I couldn't get the current draw anywhere near the same on all three legs and the motor specifications required within 5% of each other. After changing transformers several times the power company strung a mile of wire and converted the system to true three phase and everything worked fine.
Three cheers for the REA. Delta Y systems just don't support that much of a load. Ed
Chris-se-ILL
03-13-2004 20:46:02
 Re: Re: Re: Three phase power in reply to Farmered, 03-13-2004 03:19:28
Well Ed,
This system is not on an REA line it is off of an Ameren-CIPS service that runs 3 hot and a ground on the poles. There are 3 transformers on the pole that feeds the service line to the meter {3 hot wires, plus a ground feeding to the meter}. I don't claim to be any sort of expert at all about electrical wiring for 3 phase, I just know that when we test the lines that we get 120V-120V-180V There is a ground wire in the circuit box but it is not run to the motors.... why? I don't know, I can't explain it, I just know that that is the way it is! :|
At my house {which is a mile from Dad's farm} I am on an REA service (this set of lines runs one hot and one ground on the poles) and there is just one transformer at the pole, but I have 240V single phase for the house and garage available.
KeithF
03-15-2004 15:44:47
 Re: Re: Re: Re: Three phase power in reply to Chris-se-ILL, 03-13-2004 20:46:02
Chris,
I think you might want to have the power company come out and check the transformers as that is an unusual voltage. Usually transformers are connected one of two ways to get 3 phase and 120v single phase. One is the 4-wire wye and it is typically 208/120. Phase to phase voltage will be 208 and phase to neutral will be 120. The other is the "high leg" or "red leg" delta. This is usually a 240/120 volt combination. As Busdriver described it is a 240 volt phase to phase delta connection with a center tapped neutral between two of the phases to produce 120 volts phase to neutral.
Bus Driver
03-14-2004 05:33:38
The "high leg" on a Delta is phase "B" where the winding between "A" and "C" is centered tapped and that tap is grounded. The high leg is required to be marked with orange. The high leg to ground in your case should about 200-208 volts to ground, not sure how the 180 volts came to be. Only limited loads of the 120 volt supply is recommended to avoid phase imbalance with this system. That grounded tap is called the neutral for the 120 volts and is NOT an equipment grounding conductor.
buickanddeere
03-16-2004 05:35:19
 Re: Re: Re: Re: Re: Three phase power in reply to Bus Driver, 03-14-2004 05:33:38
What state are you in to have one of those ceneter tapped Deltas? I've seen wiring diagrams but nener encountered one in real life. Have run across some odd stuff such a 25 and 40 cycle equipment in old saw mills/hydro electric sites in the far north. Even a four phase system with four live lines phased 90 degrees apart. Something to be said for a nice plain boring 347/600V,120/208V 60 hz delta system. Then also the solid state variable frequency drives,plc's for control and solid state detectors instead of mechanical limit switches. Don't too many variable speed DC drives any more. The "Varadyne" drive using a "V" belt and variable sheave pulleys on the motor generator set was an interesting item too.
Dick
03-12-2004 11:19:16
Slowpoke - I have the same problem, only with an air compressor. From what I have found on this board the only solutions are - 3 phase power - expensive, or single phase motor.
As for the 3 phase controls, which I have, they cannot be used with single phase.
Please give me a holler if you find out different.
Thanks
Bob
03-12-2004 20:49:18
 Re: Re: Three phase power in reply to Dick, 03-12-2004 11:19:16
Dick,
Why can't your three phase motor controls be used with single phase? Most all have a single phase rating, as well as a three phase rating, although a given motor control will be rated less horsepower on single phase than three phase.
kjm
03-12-2004 18:38:11
3 phase converter, Not cheep but they work.
VaTom
03-12-2004 19:20:51
 Re: Re: Re: Three phase power in reply to kjm, 03-12-2004 18:38:11
Certainly not necessarily expensive either. I figure $25 will do it for cobbling a rotary converter (without capacitors). A whole lot cheaper than replacing motors, if not quite as efficient.
jeff
03-12-2004 23:02:41
 Re: Re: Re: Re: Three phase power in reply to VaTom, 03-12-2004 19:20:51
Hey guys, try to figger out some place with 2phase power. See what you can do with four or five wires! I kid not!
Slowpoke
03-13-2004 01:18:54
 Re: Re: Re: Re: Re: Three phase power in reply to jeff, 03-12-2004 23:02:41
Thanks for all the responses. The whole idea about going to a single phase motor in a steam cleaner is that it's a portable machine. Meaning you want to use it outside the shop area and will need an extension cord. I guess one could power a 3 phase converter with a 240v extension cord and bring it near the cleaner.
I've checked with the power co. about 3 phase and was told it's very costly to install; they gave the same answer when I asked about 225 amp service instead of 200 amp.
By the way, there may still be a couple of places in New York City that use two phase power. Can't remember what for tho.
RusselAZ
03-14-2004 00:22:40
 Re: Re: Re: Re: Re: Re: Three phase power in reply to Slowpoke, 03-13-2004 01:18:54
Sorry I missed your reference to two-phase power. Haven't heard that term in a long time. It is what is usually referred to as 220v single phase coming from a power box though two-phase is correct if it is two separate 110v circuits which work across each other when used as 220v. The two 110's are used in a motor to cause the phases or sine waves to be 180 degrees apart. more power from the same amperage. Three phase motors just use three positive inputs which makes the phases 120 degrees apart.
A true single phase motor needs a hot and a neutral wire to run. A "two" phase motor will run without a neutral and will not run with a lost hot lead, such as one blown fuse. This is why they can be dangerous, as the three phase can, because they may appear to be dead but still have one hot lead to the motor.
Always meter wire and motor connections for possible power and when working on equipment use grounding to clamp off the circuits DOWN stream of the switch or breaker.
RusselAZ
03-13-2004 08:15:00
The convertor doesn't have to be on the appliance. Have it mounted inside the shop and use a 4 conductor extension cord to the appliance. 3hot lines and a ground. A 10-4 S-cord should run a steam cleaner motor up to about 50 feet.
Simply; 3 phase motors run on 1 phase, or maybe closer to definition is "even" phase. 3 phase is good for starting. It's hard to show without the books with pictures but a 3 phase motor starting will close up the 3rd phase wave against the other two for starting power until the motor's speed is at phase. this is when the waveforms are even again. It's much the same thing that happens with a single phase motor using a capacitor to start. The capacitor absorbs a phasewave where is isn't needed and puts it back to a wave where it is needed to give the motor extra starting power. Motors with Running capacitors use them for kinda the same reason as they are used on motors that can have a highly variable load while running, such as air conditioning compressors. Running or starting the capacitor absorbs and smooths out erratic power cycle waves. Smart little buggers for as simple as they are.
If you do run 3 phase on extension cords, make sure anything used can only be plugged in one way as any two wires switched will reverse the rotation.
Bob
03-13-2004 20:16:40
 Re: Re: Re: Re: Re: Re: Re: Three phase power in reply to RusselAZ, 03-13-2004 08:15:00
I've heard a lot of explanations of three phase power but that's quite the line of mumbo-jumbo!!!
RusselAZ
03-13-2004 23:35:58
 Re: Re: Re: Re: Re: Re: Re: Re: Three phase power in reply to Bob, 03-13-2004 20:16:40
I said, "simply put". You can't design anything from what I said. That explanation is pretty close to what a -soon to retire- journeyman industrial electrician told me about 25 years ago. He was pretty spot on and could sit down and draw on paper the hertz waveforms that happened.
What about the explanation is "mumbo-Jumbo"? check the web link below and buried in the 101 discussion is a further explanation from a modern electrical engineer that lends a little credence to my simple words. And this is a pretty good little web site as it walks you through several motor designs to help you understand what is happening to the motors to make them run.
Gary Schafer
03-14-2004 09:51:39
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Three phase po in reply to RusselAZ, 03-13-2004 23:35:58
Those are pretty poor references. Even the so called engineer doesn't have it all right. Most of the others (on woodweb) are so far off it is hard to tell what they are talking about.
Common 240 volt power service is referred to sometimes as 2 phase power but that is incorrect. 120 volts and 240 volts are both single phase whether you use the neutral or not.
There is no such thing as 2 phase power on the standard 240 volt power line. 120 volts and 240 volts are all single phase. Even if you use the neutral with 240 volts and have two 120 volt circuits, you still only have single phase power. The phase difference between the ends of the 240 circuit are 180 degrees. The phase difference between one side of the 240 and neutral is also 180 degrees. It is all the same phase.
I have never seen a motor wired with two 120 volt lines. What would be the point. You would end up with 240 volts and a neutral in the circuit. There would be no current in the neutral.
A 3 phase motor does not "close up or eliminate" a phase after it is running. It uses all 3 phases to extract power from. You can think of it as "filling in the gap" between the power on single phase. More average power is there at a given time.
With the phase converters there are capacitors in them that "shift" the phase of the power to be applied to one leg of the motor but as others have said they are not as efficient as true 3 phase power.
A true motor/generator is the only way to get real 3 phase power from single phase power.
Regards
Gary
Bob
03-14-2004 08:38:45
I know how and why a 3 phase motor runs. It is quite obvious certain others don't.
Slowpoke
03-14-2004 00:41:34
From the Cedarburg site it looks like efficiency is compromised unless one uses a rotary converter. The solid state units allow motors to only reach 70% efficiency, while the rotary converters will provide up to 100%. If I have a 3hp converter of either type, I can start a 3hp motor and then start a one hp motor.
But can I start only the one hp motor by itself?
If the one hp is running, can I also start the 3hp, or does the one hp have to be stopped first?
I guess it would all be in the instructions anyway.
