Tool Talk Discussion Forum
Small steam cleaners
Slowpoke
03-12-2004 00:08:24
Has anyone had experience with jewelry steam cleaners? They are rather small compared to equipment cleaners, but do they have the capacity to clean chain saws, string trimmers, etc.? They have a gallon or two tank and make steam on demand with a pump and flash boiler. New ones are $500-$900, but can be found used on Ebay for about $150.
gardener
03-15-2004 18:01:25
 Re: Small steam cleaners in reply to Slowpoke, 03-12-2004 00:08:24
I didnt know about the ones you mentioned , but i have just got one of those 1-quart "Euro-pro Shark" steamers made for household hardsurface cleaning. I never thought about using it for my chainsaw, etc.I'll let you know how it works. I paid 150. canadian, at Canadian Tire Store.
Slowpoke
03-15-2004 23:54:42
 Re: Re: Small steam cleaners in reply to gardener, 03-15-2004 18:01:25
Keep us posted on your cleaner. I tried a clothing steam cleaner once, but the steam kind of flows out like smoke, with no pressure.
Those jewelry steam cleaners only put out steam for about a minute, at 350�-550�, 80-100psi. The steam is very "dry", comming out of a short nozzle. The steam is so dry that jewelry can be cleaned while on display. Maybe a hose of 3-4' would cool it enough to get some moisture to flow the dirt and crud away on a saw or trimmer. I just don't want to spend $150-$200 to experiment.
gardener
03-16-2004 18:14:00
 Re: Re: Re: Small steam cleaners in reply to Slowpoke, 03-15-2004 23:54:42
OK , i tried my steamer on the dirty chainsaw.
It takes a couple minutes to preheat, but then pumps a continuous stream of steam. If i do 15 sec on and 15 seconds off, the blast is more intense. This is with a 4'hose and a single angled fine point nozzle and squeeze-grip valve.It spewed a bit more focussed than a boiling kettle with a small hole in the spout.
1450 watts, stainless steel container.
It sounds like it's more effective than the clothes steamer you described, but not as powerful as the jewelery one. They advertise this to clean your bathtub grout, car rims,sterilize your counters and toilet bowl, etc.but also have attachments for drapes,floors,carpet.
It took me about 15 minutes outside to clean the clutch/sprocket cavity on my saw, leaving the blade attached. It was 31 deg. and the cold definitely slowed it down. It certainly didnt fling the oilsawdust all over the place as with compressed air, but was a different kind of mess instead. Usually i just have my dedicated flat pan to set the saw on and my 2 sizes of brushes with diesel fuel or varsol to clean my saws. I'll try it again in warmer weather.
