Tool Talk Discussion Forum
Plasma Cutter
Kevin
03-10-2004 15:02:17
I am looking to buy a lighter duty plasma cutter for around the home/shop use and was astonished at how many brands there are out there. I will be purchasing sub 1000 dollars and am ready to hear the good, the bad and the ugly!
Also, does the 200v version really allow you to cut thicker stock as they claim?
leaddog
03-23-2004 19:29:36
 Re: Plasma Cutter in reply to Kevin, 03-10-2004 15:02:17
I just bought a thermal Dynamic 81. 1850 on ebay. rated at 7/8 fine, 1in good and severs 1 1/4in.and it does all that FAST. It is a really nice unit. Its the latest one out and has the new 1torch that just screws in so you can change it over to a machine torch fast. Consumables are very reasonable and usually available locally but if not all over the web cheaper. They have the smaller sizes that are cheaper than other brands and are very highly recomended
Farmered
03-13-2004 04:02:11
I used to write quite well with a quill and inkwell and then someone showed me a ballpoint pen. LoL!
Cliff Neubauer
03-11-2004 10:16:19
I purchased a Thermal Dynamic's Cutmaster 50 earlier this winter and so far have been very pleased with it. It will clean cut 1/2" steel and cost $1,500 but they have a smaller model that should be around $1,000. Hypertherm and Thermal Dynamics are both owned by the same company so their products should be of comparable quality. The dealer I got mine from sells both Miller and Lincoln welders but when it comes to plasma cutters they really like the Thermal Dynamic's. As the other poster said check to see what brands you can get parts for locally, you don't want to buy an off brand model only to find out that in a couple years you can't get parts for it.
Wayne
03-10-2004 20:32:13
The other posts are right in that you can't beat a plasma for normal cutting,m especially on thinner material. The speed at which you can cut with it and the small size of the actual kerf mean less heat into the material therefore less chance of distortion in the piece your cutting. Also dirty, rusty, painted metal that you would have a heck of a time cutting with a torch is a snap with a plasma. If you've ever done any carbon arc gouging then you'll love a plasma too. We've got an 80Amp machine and it took what used to a loud, nasty 2 1/2 day job (that left you blowing black snot all night) with a carbon arc and cut it down to a little over 1 day. Then throw in the fact it made alot cleaner cut and required alot less cleanup after the part was gouged out and that just made it even more nice. Figure out how big you think you might need and then go one size bigger because I guarantee you that once you get started and get used to it you'll find more uses for it than you origionally planned.
ShepFL
03-10-2004 18:22:11
I am really confused as to why one needs a plasma cutter. So far all of my metal work has been done with torch or stick welder. Cutting is normally done with the torch or hacksaw.
I always pictured plasma cutters as tool & die shop equipment. Someone enlighten me.
Thanks
Rod (NH)
03-10-2004 19:19:08
 Re: Re: Plasma Cutter in reply to ShepFL, 03-10-2004 18:22:11
Hi there Shep,
I agree with the others.
One really never needs a different tool when you have something that works at all. However, a plasma cutter is an excellent companion to the oxy/acet torch and the hacksaw. All have their place but the plasma cutter shines when you are talking relatively thin sheet materials. Some advantages:
1.Clean, smooth cut needing little if any post cut work.
2.Narrow kerf.
3.No open flame for less fire/damage hazard, particularly in auto work around electrical wiring, etc.
4. No globs of molten slag falling out under the cut - just lots of fine sparks.
5. Fast.
6. Usable on different materials such as aluminum that the torch won't work on.
7. Uses compressed air and not expensive gasses.
8. Easily portable - some units have built in air compressors.
9. Tops for sheet metal work.
10. Low heat input to the piece - can handle soon afterwards.
Once you've used one, you'll never use the torch within that cut range again. One caveat: most manufacturers have both "recommended" and "sever" or "maximum cut" capacities for their machine ratings. I recommend staying within the "recommended" capacity for best performance. Going over that and the advantage over the torch gets less and less. I have a Hypertherm Powermax 350 which is a 25amp machine with a recommended cut of 1/4" and a maximum cut (sever) of 1/2". I would not usually consider using it over 1/4". The torch would be a better choice unless the open flame caused a problem for some specific job. Mine is the predecessor of the current Powermax 380.
third party image Rod
john
03-10-2004 19:01:11
Shep,
until you've drug a plasma torch over a piece of painted metal and the burned away paint is only a kerfs width wider than the kerf itself and you can hold the metal in your hand...you can't appreciate a plasma machine..
I know there are torch artists out there who do beautiful work... but with a plasma machine we all can do beautiful work... if you can pull the plasma torch beside a straight edge you can make a straight cut... it's still not that easy with OA for me...
take my money and my food and a couple of my kids... but please don't take my plasma cutter !!!! :-)
john
kyhayman
03-10-2004 18:58:32
Necessary? well necessary is relative :-). I could get by with an oxyacetylene rig with a heating and welding tip, a cold chisel, some wrenches, and a big hammer. :-) but I like an electric welder and air tools.
I only use one rarely, and dont have one at the shop at home but do at work. For body work and thin sheet steel it is almost essential. Really useful on steel less than 1/4", especially inside cuts; clean, no warpage, and fast. If I was doing fabrication work at home I'd need one there.
wh
03-10-2004 17:48:07
bite the bullet and buy a hypertherm 600. will cut to 3/8". cost around $1600. buy it and don't look back!!!
Jeff in Va.
03-11-2004 09:10:02
 Re: Re: Plasma Cutter in reply to wh, 03-10-2004 17:48:07
I agree with Kevin. I just bought a new Hypertherm 600 for $1475 in the Richmond, Va. area. Hypertherm advertises that it will cut 5/8" and "sever" 7/8" I have only used it on sheet metal and 1/4" CRS so far, and it cuts exceptionally well. When I was looking, Hypertherm and Thermal Dynamics were recommended most.
LesWV
03-10-2004 15:34:33
If you were to whizz in a 120 volt and then a 220 Volt socket. Which would light you up more?
For a good light duty cutter that can do up to 1/4'' stuff for less than a grand. Look at the Miller Plasma King 30 220 Volt unit for less than $900.00. The Plasma King 20 that operates on 110 Volts can only cut thickness of 3/16" in mild steel. Yet it cost the same.
The better deal is the Miller Spectrum Thunder 230V. It also is rated to 1/4" but has its own built in air compressor. It is priced at just a little over $1000.00.
You can check them both out at
www.weldingdepot.com
and
www.weldingmart.com
Below is a link to the Miller Spectrum.
Bob
03-10-2004 17:24:53
 Re: Re: Plasma Cutter in reply to LesWV, 03-10-2004 15:34:33
Actually, if you were to "whiz" in the 120 Volt socket, you would be exposed to a greater voltage to ground (120 Volts), than if you "whizzed" in the 220 Volt socket (110 Volts to ground)!
As far as which unit to buy, the "consumables" are an important factor.
What is the relative tip life between the units?
What is the replacement tip cost?
Are the tips stocked locally?
