Tool Talk Discussion Forum
V belt pump to serpentine engine
Catskill Pete
03-10-2004 11:55:58
The previous post concerning the Jeep pump got me to thinking about a problem I've been trying to figure out. I was given a Western plow with hyd. pump that runs off a v-belt. I would like to mount it on a 95 chev with a 350 that uses a serpentine belt. Anybody know of a source of adapter pulleys, ideas, suggestions,etc?
Ben in KY
03-11-2004 11:58:58
 Re: V belt pump to serpentine engine in reply to Catskill Pete, 03-10-2004 11:55:58
One question. Will the pump handle the RPM's the truck will run ? Tractors and PTO's run a LOT slower. Maybe no problem, just a thought.
Catskill Pete
03-11-2004 15:50:24
 Re: Re: V belt pump to serpentine engine in reply to Ben in KY, 03-11-2004 11:58:58
No problem about the pump RPMs, the pump is from another truck.
T_Bone
03-10-2004 17:04:08
Hi Pete,
Check with a auto AC supplier, not a auto parts store, as they use the same clutch for truck AC units as the hydraulic units use.
T_Bone
Chip
03-10-2004 14:59:06
Check with a truck shop,one that installs plows,dumps,hoists,etc.,one thats been around awhile. Don't know if still available,but there used to be a whole assortment of pulleys to mtg on alt to do that. Elect/hyd got popular & engine driven became fewer & fewer.A good alt shop may fix you up.Like other post,add a crank or w/p pulley. Depends on where you mtg it for belt clearance,alignment,ratio.Shop I worked at welded pump mtg to alt brkt,added pulley to alt,same size as alt.Slower the pump,slower hyd action=longer pump life.Snowplows really arn't critical,long as it works.
Brokenwrench
03-10-2004 13:06:13
Just find an old style chev crank pulley that will bolt to the front of the balancer in front of the serpentine pulley. Might take a trip to the junkyard to find the right one,but there are about 25 different diameter/different backspace pullies depending on which engine you pull it off of.
Catskill Pete
03-10-2004 18:27:25
 Re: Re: V belt pump to serpentine engine in reply to Brokenwrench, 03-10-2004 13:06:13
Thanks for the ideas. I will following up on the them, I like the hyd. units much better than the electric. [Ya suppose I been hanging around old tractors too long?]
