Tool Talk Discussion Forum
Way off Jeep
kjm
03-09-2004 17:51:39
I need info and this is the best page on the net so here goes,1994 Jeep Grand Chreeke full time 4x4. It acts like the front dif is locked in all of the time(turning in a parking lot it will scoot and jump) I have never been around these full time 4x4 before and this is driving me crazy. Thanks KJM
Paul Janke
03-11-2004 14:11:54
 Re: Way off Jeep in reply to kjm, 03-09-2004 17:51:39
You should be able to jack up one corner and turn that tire without the others turning. The axle and transfer case differentials should let you do that. If it has limited slip differentials in the front or rear end, you may need to jack up one whole end of the vehicle so both tires on that axle can turn. If jacking up one end and turning a tire causes the other to turn the other direction, that axle is not limiting the slip. I hope I am not muddying the waters.
kjm
03-11-2004 20:26:50
 Re: Re: Way off Jeep in reply to Paul Janke, 03-11-2004 14:11:54
Paul, I know what you are talking about.Tonight turned into a Hazmat study night.74pg book and tests has to be done by Sat. morning 9:00am and I was told about it at 3:00pm today. I`ll check the Jeep Sunday after church. Thanks, KJM
Mike
03-10-2004 13:20:34
Sounds like you are stuck in 4w lock.The 4wd turns the whole time,even when its not in use,but has a disconnect of some sort to take it out on dry pavement. There may be a vacuum or electrically operated servo that locks the 4wd,usually found on the front axle. Could be a stuck servo,short in the electrics,or frozen shift mechanism that are holding it in lock mode.If you have the push button 4wd it may be the control module. Try pulling the fuse for 4wd,or transfer case and see if that straightens it out.My wifes did what yours is doing, after several trips to the shop,I finally put a switch in the feed line to lock it in if needed. Mine had a bad control module ($550).
kjm
03-10-2004 20:14:28
 Re: Re: Way off Jeep in reply to Mike, 03-10-2004 13:20:34
Mike, That is just how it acts but it is full time 4x4 there is only High N Low but I have not been under it to look for a switch on the housing. I will start looking tomorrow night. Thanks, kjm
Terry in KY
03-10-2004 12:32:32
Either that or you have a "Lincoln Locker" -- where you take a Lincoln welder and weld the front diff solid. This is really good for off road use only, but I know people who have tried it on the street. Usually somethine ends up breaking.
Terry
DaveCA
03-10-2004 05:00:26
Needs an oil change in the diff. Use only oil specified for limited slip diff,
kjm
03-10-2004 20:23:56
 Re: Re: Way off Jeep in reply to DaveCA, 03-10-2004 05:00:26
Dave I wondered if it had a limited slip in the front. Thanks for all of the help, I`ll start looking Thr. night. I have to get this fixed I paid 4000.00 for it.(this is the tractor part,
I traded labor on a bunch of tractor repairs for the Jeep) and it looks like new runs good but you can`t turn it! kjm
