Tool Talk Discussion Forum
Oxy-Propane cutting / regulator icing
James
03-09-2004 09:15:12
I have been cutting with my Oxy - Propane rig and have noticed that the Oxygen regulator becomes covered in a thin layer of ice after a while. Is this O.K. or is it Dangerous?
T_Bone
03-10-2004 18:21:45
 Re: Oxy-Propane cutting / regulator icing in reply to James, 03-09-2004 09:15:12
Hi James,
Take it to a weld supplier that does repair and have it tested. Most regulators can be rebuilt for a resonable cost.
T_Bone
Mark
03-09-2004 19:09:16
You spell leakeee. When gas expands, it absorbs heat. The leak sucks the heat out of your regulator making it cooler than the surrounding atmosphere. Normally the atmosphere contains moisture. Cold regulator condenses the moisture into a wet coating, but with excessive gas pressure release, more compensation is available so instead of wet, (wet and wild) is it frozen. This is the basis upon which all air conditioning systems are based.
Dangerous, probably not if in a well ventilated area. Expensive..... absolutely.
Mark
