Tool Talk Discussion Forum
another pump question
Cooker.308
03-08-2004 09:54:02
Was reading about someone else's pump problem here today, when I came in for dinner I had one too. I have a shallow well system,my water will run gravity feed into my basement. My problem is the pump keep cycling,30 to 50 psi. I have a shutoff on my i/2 in copper right at the pump. It is shut off, I shut off the feed from the well, drained the pump,and checked the pressure tank,which is right on top of the pump, pressure in tank was 20. I am thinking my problem is my foot valve, looking for a secong opion before I get into going into the well. Also what does a water logged tank act like? Thanks in advance.
BillR
03-08-2004 23:12:10
 Re: another pump question in reply to Cooker.308, 03-08-2004 09:54:02
If you shut off the outlet and it still cycles (you're not using water but it's still cycling) then it's probably a bad foot valve. Could also be a significant leak in the pipe.
LesWV
03-08-2004 10:07:23
Look on the water tank. If you have a valve that looks like a car tires air valve. Add 30 to 40 lbs of air to the tank. My water system cycles often if it becomes water logged. When I add air to the tank it will stop all of the cycling for a week or two and operate as it should.
Tree Farmer
03-08-2004 19:47:32
 Re: Re: another pump question in reply to LesWV, 03-08-2004 10:07:23
When my system would get waterlogged, the pump would start if you took out only a glass full (no live water). Would have to drain the pressure tank completely out and start over. New tanks are available with a bladder to seperate the water and air, probably the way to go.
